Pickle fork question
Old Oct 12, 2007 | 08:51 PM
72350auto's Avatar
72350auto
Default Pickle fork question
Hey all. I'm taking my top A-arms out to install new bushings and ball joints. The pickle fork I have has an opening of 7/8 inch which seems to ride high on the ball. Question I have is should I be using one that is closer to the width of the shaft or does it matter. Ball joint shaft is just under 5/8 inch. Thanks
Old Oct 12, 2007 | 09:19 PM
72LS1Vette's Avatar
72LS1Vette
If your ball joints are original they are riveted into the control arm so a pickle fork won't do you any good. You have to grind off the tops of the rivets, pry the balljoint off and then remove the remains of the rivets. New ball joints usually come with bolts - you will have to enlarge the holes slightly for them to fit. If you are doing a NCRS restoration you can also get new rivets instead of bolts.
Rick B.
Old Oct 12, 2007 | 09:33 PM
stingr69's Avatar
stingr69
The pickle fork is to separate the ball joint stud fom the spindle. I do not even bother with them. You can whack the spindle near where the tapered stud goes through and the spring pressure will pop it apart. Only takes a whack or two and the rubber boot will be spared.
Just another way to get the job done.
-Mark.
Old Oct 12, 2007 | 11:24 PM
72LS1Vette's Avatar
72LS1Vette
I mis-read the question the first time. If you jack up the bottom control arm to compress the spring a bit, loosen the upper nut several threads and lower the jack the ball joint will probably drop free (maybe with a few whacks for good measure). Remember that the spring is still under tension so be careful - fasten a chain around the arms for safety. Lars has a paper on rebuilding front suspensions that will probably answer all of your questions. The 2 suspensions I have dismantled were both on bare frames so I used a somewhat more Bubba method to get the ball joints loose. My earlier post referred to the removal of the ball joints from the control arm.
Rick B.
Old Oct 12, 2007 | 11:32 PM
The Spark's Avatar
The Spark
I used a socket and bolt to make a press to push the upper ball joint loose.
http://www.thespark.us/frtsuspension.htm
It worked great.
Old Oct 13, 2007 | 01:06 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Pickle forks are worse than useless. JC Whitney sells two different versions of the proper tools to separate ball joints. One looks like a little press, the other (and the one I prefer), looks like an "H" with a bolt running across one end.
Old Oct 13, 2007 | 10:05 AM
eastltd's Avatar
eastltd
-Mark.
This is likely how a mechanic on the clock would do it. Time is money!
Old Oct 15, 2007 | 08:59 PM
72350auto's Avatar
72350auto
OK well in the end that wasn't so bad, used a combination. I put a pitman arm puller on the bottom side pushing up on the ball joint bolt and loaded it. Then I put the pickle fork in and two small whacks and pop. I could have probably just kept loading the pitman arm puller till it popped, but I hate loading them things. The H tool you guys described gave me the direction to this. Thanks very much to all.
I was going to use a spring compressor on the spring but I can't get enough of the spring to use it. Is the spring compressor usually installed after the lower ball joint is undun?
Thanks again
Old Oct 15, 2007 | 09:10 PM
68_72Shark's Avatar
68_72Shark
You shouldnt need a spring compressor. I removed mine a few months ago and didnt use one. I used a floor jack under the lower control arm, backed off the nut from the upper ball joint but left it on the shaft, then separated the upper joint using a tie rod puller. Next pulled off the nut and lowered the lower control arm with the spindle attached and removed the spring.
Old Oct 16, 2007 | 11:01 PM
72350auto's Avatar
72350auto
Well the spring came out relatively easy, didn't use a compressor as advised and had no problem. I did put a chain around it but that was not needed either. I think the hardest thing of all was getting the lower control arm shaft to come free at the rear bolt. That was good for about 40 minutes . Now comes the hard part I guess, gettin them old bushings out and the new ones in. Thanks to all for the help.
To Pickle fork question
