Need tach help
Old Oct 16, 2007 | 11:39 PM
blkonblk_c5's Avatar
blkonblk_c5
Default Need tach help
I'm working on a 78 vette the tach doesn't work but if I bypass the external capacitor it does work. is that capacitor used to smooth out current flow for a steady needle only or is it used for curcuit protection too? "will it hurt to leave it bypassed" as much info/help as possible would be very appreciated. thanks Jon
Old Oct 17, 2007 | 12:40 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Mine worked without the "Tach Filter" that you are referring to for at least 25 years...just recently had to change the tach circuit board...I think there are 100's of opinions on this one...but yes the can is supposed to send spikes to ground protecting the Tach Circuit Board.
Old Oct 17, 2007 | 01:35 PM
...Roger...'s Avatar
...Roger...
Is your capacitor plugged into the Tach wire or the Pink pos.Battery distributor wire?
Old Oct 17, 2007 | 02:07 PM
blkonblk_c5
its in line with the tach wire the one that sends current from the distributor to the tach.
Old Oct 17, 2007 | 02:47 PM
...Roger...
This shows it should be on the battery lead.
To Need tach help
