Brake light problems
Old Oct 20, 2007 | 09:49 AM
Beneja's Avatar
Beneja
Default Brake light problems
My 1968 was driving me crazy with a brake light problem. The left brake light would not work at times. The rear wire harness was replaced two years ago. I re-did the grounds, checked the connectors, and checked the new harness for continuity and voltage. Everything would check out but it would give me problems from time to time. I finally found that the turn signal lever would droop when I hit a bump. The lever would move enough to interfere with the brake light but not turn on the signal. My next project is to replace the turn signal switch. I chased this problem for a few months so I hope this info may help someone else.
Old Oct 20, 2007 | 11:55 AM
Durango_Boy's Avatar
Durango_Boy
Have you tested all the contacts in the sockets to make sure you are getting ground and 12V at each contact when the appropriate switches are applied?
Old Oct 20, 2007 | 12:01 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
i had that same exact problem with my 68.the turn signal switch turned out to be the culprit.
Old Oct 20, 2007 | 12:37 PM
ksbunting's Avatar
ksbunting
Good information, and thanks for sharing it.
This is the kind of weird problem that has one tearing their hair out (and some of us don't have that much anymore)
Kurt
68 coupe
To Brake light problems
