Wiring Engine for Bench Test
Old Oct 20, 2007 | 07:08 PM
kaiserbud's Avatar
kaiserbud
Default Wiring Engine for Bench Test
Guys... I have the motor in the car, without any wiring harnesses. I just want to fire it up and have the motor running.
Can you offer any advice on how to wire it temporarily? This is a frame off and the chassis is fairly well back together and has the motor in it.
Just FYI...
Ground strap motor to frame installed
Starter on, mototr mounts in, Auto Trany flexplate disconnected
Ignition Coil and Distributor set, wires on.
Motor was already dynoed - but with different carb, dist, headers
No gauges , no alernator currently (no pun intended)
