DOT5: Which Brand?
Old Oct 24, 2007 | 01:45 PM
stinger12's Avatar
stinger12
Default DOT5: Which Brand?
Which brand of DOT5 brake fluid should I be using? Does GM make some?
Old Oct 24, 2007 | 03:40 PM
stinger12's Avatar
stinger12
bump
Old Oct 24, 2007 | 04:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You shouldn't. DOT 5 is typically silicone based, which is compressible and hard to bleed the air from. Unless you're racing, just sitck with a good mineral based fluid such as Castrol GT LMA Dot 4. It's available everywhere, it's cheap, and it's better than it has to be for most drivers.
Old Oct 24, 2007 | 04:25 PM
garage-ghost's Avatar
garage-ghost
I use NAPA and have for years with no problems what so ever.
Old Oct 24, 2007 | 04:41 PM
roadrocket's Avatar
roadrocket
sorry to disagree with the early post but i'm a dot 5 fan. after many caliper rebuilds with dot 3 i decided to give silicone a try despite the much higher cost. with the dot 3 when i drained it after even just a few months it looked like ditch water. i recently drained the dot 5 job i did 10 years ago and it looks like the day i put it in, purple tint and all. no interior rust has got to be a good thing. i did not bleed the system once in 10 years or have any other problems at all....i'm sold on dot 5.
as for as what brand....probably doesn't matter, i would not be surprised if they all come out of the same drum.
Old Oct 24, 2007 | 05:17 PM
stinger12's Avatar
stinger12
THIS IS NOT A THREAD DEBATING OVER WHICH DOT FLUID IS BAD OR GOOD!
I specifically asked what brand of DOT5 fluid I should buy...I have already decided to use DOT 5 fluid.
Old Oct 24, 2007 | 06:21 PM
stingr69's Avatar
stingr69
I do not think the brand will matter. I think SSBC in my home town of Buffalo NY has it cheapest at about $23/quart. I bought several quarts from them and I have bought NAPA DOT-5 by the gallon but it costs quite a bit more. NAPA has it NOW when you need it NOW.
I love DOT-5 and put it all my "keeper" vehicles. Once you know the tricks on how to use it, you will probably stick with it.
-Mark.
To DOT5: Which Brand?
