The fun never ends with this engine install...
Old Oct 25, 2007 | 04:14 PM
cduemig's Avatar
cduemig
Default The fun never ends with this engine install...
So I'm getting soo close to having my new 383 running in the newly painted engine bay, but of course I have run into a few last minute problems...
I bought a set of custom chrome valve covers for my 383 stroker but when I went to put them on I realized the heads are new style and they won't fit. I decided to just buy an adapter for them. I had to remove the rockers to install the adapters and just realized today that even though I thought they didn't get in the way of the rockers, they do rub I guess the valve covers and adapters are out ($280 down the drain) and as an added bonus, in the two weeks the adapters were on, one of the studs broke off flush in the head (it wasn't even torqued down, just snug in the block).
What's the best method of removing the stud from the head? I'm a bit leary in removing it because of how small it is and being in the aluminum head...
Anyone looking for chrome "383 Stroker" emblem valve covers? I'll cut you a great deal... Guess I should post that in the parts section...
Old Oct 25, 2007 | 07:11 PM
Road-Race Vette's Avatar
0Road-Race Vette
Former Vendor
your best chance for taking that stud out is with a high quality ez out kit from a reputable manufacturer.just be careful not to damage the head.What i am not clear on is on what is hitting your rockers. the valve covers or the adapter spacers? We had installed the spacers on a set of heads because the customer didnt like centerbolt valve covers and they didnt hit anything.
Old Oct 25, 2007 | 10:04 PM
pbcanney's Avatar
pbcanney
Are they hi rise or stock height? My 383 has hi lift rockers
pm me or email pbcanney@hotmail.com
Old Oct 25, 2007 | 11:50 PM
cduemig's Avatar
cduemig
I believe they are comp 1.6 roller rockers. They are pretty big and the adapter won't clear in between the intake and exhaust rockers so I pulled them off and now the roller pin (or whatever it's called) is sitting right on the adapter plate and won't fully set in. If I try to thin the adapter I don't think it will hold up well enough so I just bought some new chrome center bolts and calling it a day. Here you can see my engine specs, mine was built a year ago, but as far as I can tell, it's the exact same build and the same builder...
http://cgi.ebay.com/ebaymotors/TRICK...QQcmdZViewItem
Old Oct 26, 2007 | 12:23 AM
pbcanney's Avatar
pbcanney
well. shoot me a pic of the valve covers
Old Oct 26, 2007 | 06:10 PM
cduemig's Avatar
cduemig
Well, I def did it this time. I bought an easy out kit from autozone and went to work. It's a cheaper kit (mistake #1). When I began drilling, it didn't occur to me that when the stud sheared, it didn't sheer perfectly flat therefore causing the bit to slide down to the edge near the head, and I didn't have a punch to set the initial hole (we'll just call that one mistake #2). Then after I got a hole drilled that looked well enough I put the easy out in the drill (mistake #3) the whole time asking, why is the end of this squared? That doesn't fit in a drill well... Then in drilling out snapped off the end of the bit (mistake #4, but who's counting?) I now have the stud, I knicked the head a little bit and have an easy out broke off in there. I think it's about time to throw in the towel and give this to a professional. I'll clean it up and tow it into a machine shop. My guess is they'll have to drill it and either heli-coil it or fill it and retap the hole. If I wasn't me, I probably wouldn't let me touch that car
Old Oct 26, 2007 | 06:12 PM
cduemig's Avatar
cduemig
Here's the valve cover pics... I paid $140 + shipping off ebay. As long as you don't live in Siberia or something, I'll take $75 shipped to your door...
Old Oct 26, 2007 | 06:52 PM
Bob Onit's Avatar
Bob Onit
Did the EZ out break off flush?
If theres any of it left above the stud it should come right out
If you can get a good grip on it just crank it clockwise and see what happens.
I'd also bet that the center bolt covers wouldn't leak with only 3 bolts holding them down so you would be able to drive it to a shop rather than tow it to save some $$$.
Old Oct 26, 2007 | 07:12 PM
pbcanney's Avatar
pbcanney
pm to you
Old Oct 26, 2007 | 07:28 PM
cduemig's Avatar
cduemig
No, there's still plenty of the ez out left to pull out, but I tried with channel locks to get it to turn though, honestly I didn't try that hard, I'll work on it some more. I should have had my shop-vac there while drilling.
Old Oct 26, 2007 | 07:46 PM
Bob Onit's Avatar
Bob Onit
Use Vice Grips and get a really tight grab on it and turn it clockwise.... should come right out.
Then get a quality EZ out (don't use a drill) and pull that stud out of there.
I'm not sure if you have bolts, or studs with nuts holding the valve covers down. If they are bolts then it should come out quite easily because the hold downs don't require much torque at all and shouldn't be bottomed out in the hole.
Old Oct 26, 2007 | 08:14 PM
VCuomo's Avatar
VCuomo
Where did you get the valve covers from, if you don't mind my asking?
Old Oct 26, 2007 | 09:06 PM
cduemig's Avatar
cduemig
I bought them on ebay about six months ago. He had several more, I'm pretty sure he made them. I haven't seen them on there recently. I just did some poking around and I'm not seeing anything.
To The fun never ends with this engine install...
