I think they are the exact same. On the '70 the Camaro's LT-1 was rated 10 HP less due to exhaust difference. I know the '70 rating was Gross and shouldn't have included anything about the exhaust system. Probably marketing.....
One of the car mags of the day (I still have it somewhere) had a 70 LT1 Vette and a 70 1/2 Z28 nose to nose with the tag line "Only your time slip knows for sure" or something close. 1/4 mi. times were within a 1/10 with the edge to the Vette. The only difference was the exhaust manifold and the Camaro had a single muffler w/two pipes in/out, a few pounds difference in weight, and $3000 lighter on your wallet. /:\
"... Today it [LT1] is probably even better known as the Z28, which is what it is called when ordered in the Camaro. Corvette engineers originated the idea so Duntov winces when you say the two engines are the same, but they are...."
There are several differences between the Z28 engine in the Camaro and the LT-1 engine in the Corvette for 1971.
1. Exhaust manifolds completely different design. Camaros are log style more restrictive, Corvettes are rams horn style design and freer breathing.
2. Camaro uses conventional points/condensor type ignition, Corvette uses the magnetic pulse transistorized ignition set-up, far superior.
3. Camaro uses a dual snorkel air cleaner housing assembly. Corvette uses a 14 inch open element air cleaner assembly.
So if the engine was put in a Corvette with the Corvette exhaust manifolds, the Corvette air cleaner, and the Corvette ignition, all things are then equal?
I'm asking because a LT1 Corvette I am looking at has the Z28 LT1 block in it.
