77 Transmission leaking intermittently
Old Oct 28, 2007 | 12:11 PM
ripepsi's Avatar
ripepsi
5th Gear
Default 77 Transmission leaking intermittently
My 77 Corvette transmission leaks intermittently. It can go weeks without a single drop, then one day there will be a nice puddle on the floor. I have inspected the underside of the car and am unable to find the leak. Any ideas? the leak appears to be coming from the towards the front of the transmission near the passenger side.
Old Oct 28, 2007 | 12:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Front tranny seal is the most likely culprit, especially if the car sits for long periods between drives.
Old Oct 28, 2007 | 02:14 PM
Artsvette73's Avatar
Artsvette73
Front pass side either the tv cable seal, or dipstick tube seal, or both
Old Oct 28, 2007 | 08:12 PM
mdbelanger's Avatar
mdbelanger
May be that excuse to go for the 2004R
Old Oct 28, 2007 | 10:57 PM
Artsvette73
My thm350 didn't leak and it shifted fine. That was my excuse to put a 2004r trans in. You will like it. Oh and it dosen't leak
Old Oct 28, 2007 | 11:15 PM
78Vette-SA's Avatar
78Vette-SA
if it's an automatic. I just had to replace the dipstick tube o-ring seal on a 77. I have 100's of 0-rings in a kit lying around. Not one would fit the tube correctly. Ordered GM replacements, would only come in a pack of something like 12 or 20. Gotta love GM.
Old Oct 29, 2007 | 04:42 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
If The Transmission Fluid Get Below A Certain Level....On Mine The Transmission Pump Can Pick-Up Air, And Foam up On Acceleration....And Puke Fluid Back Out Of The Dipstick/Fill Tube. If I Do Not Keep The Fluid Topped Off...Then It will Puke Fluid On To My Exhaust Headers...Blue...Smoke....Trail ! Check Your Fill Tube To See If It Is Oily.
Old Nov 3, 2007 | 03:59 PM
ripepsi's Avatar
ripepsi
5th Gear
It was the dipstick tube seal that was leaking. Thanks!
To 77 Transmission leaking intermittently
