identify rear shock mount
Old Oct 28, 2007 | 07:08 PM
elecriciandude's Avatar
elecriciandude
Default identify rear shock mount
I need to replace a shock mount, and beings there is a left and right(ok, I didn't know there was a l/r untill after the fact) after the cleaning up parts One needs replaced. What identifies the difference for left or right? One has a shoulder towards the strut rod shaft and one doesn't. If anyone knows, appreciate the help,Terry
Old Oct 28, 2007 | 07:55 PM
SIXFOOTER's Avatar
SIXFOOTER
Mine is all put together so I can't see the flat on the stud. The mount goes into the carrier from the front and the shock mount points to the center of the car
Old Oct 28, 2007 | 08:02 PM
elecriciandude
Thanks for the reply, but I can't tell which side the one i need to replace came from,Terry
Old Oct 28, 2007 | 08:45 PM
65GGvert's Avatar
65GGvert
The flat side goes down, so hold it with the part that goes through the strut rod pointed to the back of the car and the part that the shock goes over toward the center of the car. If the flat side is down, that's the side it goes on. You could also just look at the fork that sticks out from the trailing arm and see the flat is down and figure which way it turns to face toward the center of the car so the shock will mount.
Old Oct 29, 2007 | 06:54 AM
corvetteload's Avatar
corvetteload
Replace them both and start anew------PROBLEM SOLVED!!!!!!
To identify rear shock mount
