76 headlight bushings
Old Oct 30, 2007 | 10:33 AM
original76's Avatar
original76
Default 76 headlight bushings
Has anyone changed headlight bushings? What is the best way to do this chore? Advance thanks for any tips!
Old Oct 30, 2007 | 03:53 PM
seventysixvette's Avatar
seventysixvette
I changed mine when I completely rebuilt both my assemblies. But I cheated, I had both assemblies out on a work bench (still do) while I replaced my header panel. They weren't hard to get out or anything. I'd check close and see if the door bearing are tight while I was at it. One of mine was wore bad.
John
Old Oct 31, 2007 | 08:05 AM
jnb5101's Avatar
jnb5101
it's a straight forward job. only two problems i had in disassembling the headlights were the collars on the pivot bushings. had to heat them with a torch to loosen the set screws. several of the #8 screws that held the adjuster brackets and the headlight cups in place snapped off, even though i soaked every screw and bolt with blaster for a week before i tried to remove them. drilled them out and rethreaded them.
jeff
To 76 headlight bushings
