Stainless Trailing Arm Bolts
Old Nov 1, 2007 | 06:51 AM
Burnt71's Avatar
Burnt71
Stainless nuts can seize on a stainless bolt and you will have more trouble than using the grade 8. Use the grade 8.
Old Nov 1, 2007 | 10:16 AM
68RATVT's Avatar
68RATVT
Yep, stainless can sieze, most people don't know to use anti-sieze or bar soap on them first,it keeps the threads from heating and locking up,only seems to be a problem on the first use, after that your good. Another very good source is Totally Stainless or http://www.mmsacc-stainless.com. I spend the extra $ to buy the best and easiest to clean.
Old Nov 1, 2007 | 05:17 PM
Red70vette's Avatar
Red70vette
Use standard grade 8 with never sieze. The bolts you are taking out sat there for 30+ years subject to water, salt, and all sorts of elements. Unless you expect to subject your vette to those conditions over the next 30 years I would not worry about them seizing. I would worry about them being stainless and not strong enough to take the abuse.
Old Nov 1, 2007 | 05:35 PM
rexx78's Avatar
rexx78
Old Nov 1, 2007 | 06:01 PM
AirTrafficController's Avatar
Originally Posted by rexx78
Personal prefrence I guess, but I would go with the standard Grade 8. If you changed out your arms, you should be good for another 3 decades. Think about it! When I'm 72, it will be someone else's problem, whether I own the car, or not.
Old Nov 7, 2007 | 03:23 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Originally Posted by jdmick
Stainless bolts that came in the stainless shim kit here too. Don't recall which vendor but they haven't sheared off yet and it's been a few years.
I don't think that you will find the SS bolts shearing at all. Most of the concern with SS t-arms bolts(at least on our end) is that in the case of an accident, the SS bolts will shear/fracture quicker.
Old Nov 7, 2007 | 03:59 PM
rcread's Avatar
rcread
Has anyone ever had a problem with a trailing arm bolt being plated too thickly? My step-son and I spend the better part of 90 minutes trying to get the bolt to go through the trailing arm. Finally, I pulled it out and tried to push it through the trailing arm that hadn't been installed yet. I would have had to hammer it through. There is no way the long handle needle nose pliers were going to get it through. Then I got the other bolt and it slid right in. It took about 5 minutes to get that bolt through the frame and trailing arm. Guess I'll have to get another bolt.
