Control Arm bushings
Old Oct 31, 2007 | 12:09 PM
stinger12's Avatar
stinger12
Default Control Arm bushings
I installed my control arm bushings from energy suspension - do I have to put washers on the shaft to shim the inner sleeve of the bushing up past the face of the bushing...or can I just tighter the cup washers to factory specs?
Old Oct 31, 2007 | 01:00 PM
SIXFOOTER's Avatar
SIXFOOTER
Torq the bolts on the cup washers, it will pull in
Old Oct 31, 2007 | 01:08 PM
stinger12's Avatar
stinger12
Won't that also pull the control arm ears closer together though?
Old Oct 31, 2007 | 01:15 PM
Aggitated Monkey's Avatar
Aggitated Monkey
If you are installing polly bushings; put some lock tight on the bold treads then torque them.
To Control Arm bushings
