Headers: Yes or No
Old Nov 10, 2007 | 10:13 PM
emtmike's Avatar
emtmike
Default Headers: Yes or No
When I'm ready to change my exaust on my '81, I want to put a true duel on in stainless . I'd like to keep the car as original as possible and was wondering if it's worth it to put headers on?. I mean, do they give you that much more horse power and will they make a better sound compared to keeping the original manifolds on?.
Old Nov 10, 2007 | 10:32 PM
swtato's Avatar
swtato
St. Jude Donor '05
I love the way mine sound! I ahve an L82 4spd Pace Car. I want to keep fairly origional but still enjoy driving it.
Old Nov 10, 2007 | 10:53 PM
Retro78's Avatar
Retro78
Headers yes. But why stainless, are you driving it in winter/salt roads? You can always put the manifolds away, but not sure it matters much in terms of value about originality on a 81.
Old Nov 10, 2007 | 11:07 PM
emtmike's Avatar
emtmike
Right now my '81 still has the original exaust system on it. I don't plan on driving it even in the rain let alone the salt/snow. I just didn't want to go through all the work of taking off the original manifolds if it's not going to make that much of a differance in horse power or sound.
Old Nov 11, 2007 | 09:03 AM
c3andc5's Avatar
c3andc5
I have headers on my 73 L-82. Consider these pros and cons:
Pros:
1. Gives your Chevy SB or BB motor a great sound.
2. A little more HP at the flywheel.
Cons:
1. Produce a LOT of heat which can cause problems in your engine bay (damage wires, hoses, components). Coated headers can help reduce the heat.
2. The are very much in the way of doing work on your engine.
3. Header gaskets seem to fail more often.
Old Nov 11, 2007 | 09:31 AM
den(thevetteman)78's Avatar
den(thevetteman)78
Pros:
Cons:
If you are insure as a antique you might get a raise in insurance cost cause adding headers change your car from antique to modified antique. I know because i bought a set and before adding them i had my car apraise and the appraiser ( he have a '57 chevy) told me that when he added headers on his it raise his insurance cost.
Old Nov 11, 2007 | 11:14 AM
guitarcrazy02's Avatar
guitarcrazy02
My 81's stock manifolds aren't really all that bad. If you look at them, they're kind of like mini-headers with a 4 into 1 collector. I imagine they flow pretty well.
Old Nov 11, 2007 | 12:10 PM
Tall Boy's Avatar
Tall Boy
Go with ceramic, they reduce heat or better yet go with ceramic and sidepipes, helps keep your inside cool and just looks good.
Old Nov 11, 2007 | 12:20 PM
countylawdog's Avatar
countylawdog
I have purchased a set of headers and SS sidepipes for my '72, I'm sending the headers of to Jet-Hot next week for their "Sterling" coating. This will be my winter project is to install the headers/sidepipes.
I also put headers on my '89 - I like headers on vehicles.
Old Nov 11, 2007 | 12:22 PM
gator79's Avatar
gator79
get ceramic coated headers, and installing headers on a 81 is not that hard of a job. good luck
Old Nov 11, 2007 | 12:25 PM
gator79's Avatar
gator79
I am not sure on a small block, but on my big block I had to fit my headers first ( massage them for clearance ) then I sent them to jet hot for coating. just a thought
Old Nov 12, 2007 | 12:36 PM
C3 4ME's Avatar
C3 4ME
If you decide to get headers, I would also suggest having them coated. I bought my car and the headers weren't ceramic coated, and after having them ceramic coated, it makes a noticeable difference in interior heat. Again, do as suggested, make sure they fit first, in case you have to ding a tube, then send them out to be coated. Also, in 2 years of driving mine, I've never had to replace the header gaskets. I can't commment on whether it's harder to work on the car with the headers than manifolds, mine came with the headers on it. I do love the sound though, I have hooker super comps and flowmaster 50 series mufflers.
Old Nov 12, 2007 | 01:06 PM
Jims79's Avatar
Jims79
I would get your manifolds powered coated and install an H-pipe and a set of magna-flow or flow-master mufflers
Old Nov 12, 2007 | 10:21 PM
countylawdog
Thank-you
Old Nov 12, 2007 | 10:30 PM
Recon12thman's Avatar
Recon12thman
headers are the way to go. the sound that they give the SB is totally worth it in the end. thats why i cant wait to put hookers and sidepipes on my 79
Old Nov 13, 2007 | 06:34 PM
c3andc5's Avatar
c3andc5
I'm with Hagerty. Headers had nothing to do with them determining my policy premium.
Old Nov 13, 2007 | 08:09 PM
pbcanney's Avatar
pbcanney
I thought you said you were running Tri-Y's
To Headers: Yes or No
