"jeep" power steering
Old Nov 11, 2007 | 08:31 PM
jfleye's Avatar
jfleye
Default "jeep" power steering
Has anyone installed one of these systems? How do you like it. Thanks
Old Nov 11, 2007 | 08:51 PM
markdtn's Avatar
markdtn
I did mine back stock, but if I had it to do again I would definately go that way over Steeroids. I have driven a "Jeep" box in a '71 and was quite impressed.
Old Nov 11, 2007 | 08:53 PM
seventysixvette's Avatar
seventysixvette
Just go to search and punch in grand cherokee steering . I've swapped one onto mine, but I can't comment on the performance yet.
Good Luck!
John
Old Nov 12, 2007 | 01:25 AM
panic's Avatar
panic
You mean Grand Cheerokee what year model? generally when you talk about a jeep box to fix into a C3, of what year model you talk about? thanks...
Old Nov 12, 2007 | 02:32 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
http://forums.corvetteforum.com/show....php?t=1603168
99-03, I think.
Old Nov 12, 2007 | 05:20 PM
FKING1's Avatar
FKING1
Had the Jeep box put in 2 years ago. No welding or cutting involved. It is a bit sensitive , but, I like it.
http://www.corvettesteering.com/55-57%20chevy.htm
Tom is a pleasure to deal with.
Old Nov 12, 2007 | 08:22 PM
Today's problem is..'s Avatar
Cruise-In VI Veteran
St. Jude Donor '09
When you say it is a bit sensitive, could you elaborate a little bit? Is this at highway speeds making the car feel darty, or lower speeds and the car turns very quickly with little steering input?
Old Nov 13, 2007 | 04:12 PM
FKING1's Avatar
FKING1
Darty at highway speeds . OK at lower speeds.
Old Nov 13, 2007 | 04:24 PM
GD70's Avatar
GD70
Is this with power or non power steering? I have non power and wondering if it's worth the swap.
Glenn
Old Nov 13, 2007 | 04:49 PM
vettedan's Avatar
vettedan
I guess the engineers at GM got it all wrong upgrading the C4 thru C6 Corvettes to a rack & pinion steering. They should have stuck with the old worm gear box.
I'm very happy with Steeroids.
Old Nov 14, 2007 | 12:37 PM
68 NJConv 454's Avatar
68 NJConv 454
I have the jeep box too.
Its great. Feels just like my new 07 chevy trailblazer. Very minimal effort to turn the wheel and its 12:1 ratio is great. Alittle sensitive at highway speeds though. If you go with an aftermarket power steering pump like KRC you can adjust your output flow with a different size fitting which could help with the sensitivity at high speeds.
I have hooker headers and I had to really beat a dent in the side of two tubes to fit with the jeep box. I still think its too close that it is boiling the RedLine performance power steering fluid b/c I keep having to fill the power steering system with fluid. No leaks.
I read too many times about the crapy brackets of the steeroids kit and even got to twist a display model at Carsile two years ago. The darn brackets flexed right in my hands.
After my 5-6 speed trans upgrade in the next two years I am thinking about going with a rack and pinion setup if I can't solve the heat issue with the jeep box...but I want a R&P that is built well. Waiting for feedback with the new VBP R&P that just came out.
Old Nov 14, 2007 | 03:59 PM
firefighter's Avatar
firefighter
are the steeroid kits so weak that they are not worth getting and reinforcing? I don't know if I like the idea of twitchy at highway speedes. Does Unisteer make something for the C3?
Old Nov 14, 2007 | 04:56 PM
firefighter
Originally Posted by racervette69
I installed a jeep box,, I really like it,,,
wouldnt be without it. I've really hammered on it during some of the hillclimbs. A few of them have very narrow long straights where you see 100mph+,, have not felt any darting in the car. Makes the car much easier to correct before things get out of hand..
One difference is I'm running a 30% under crank pulley,
That would help if the Jeep rack gets too much pressure from the pump. Might that be a thing to consider? Pump speed/press?
Old Nov 15, 2007 | 09:07 AM
68 NJConv 454
Its all about fluid flow.
You can change this by changing the valving but you don't want to cause back pressure and burn up the pump.
Here's the catch 22.
You want enough fluid flow to have good feel and power steering at low RPM's like turning in a parking lot, stop sign ect.
Then when your on the highway your RPM's are up so your fluid flow is more which is why the steering gets twitchy and sensitive. The increased fluid flow make the jeep box much easier to turn with less road feel so you're likely to turn the wheel too much.
It has been discussed on here a few times about changing the valves but I haven't heard of anyone acutally doing it sucessfuly.
According to discussions on here...actual Jeeps have an electronic controled valve that changes depending on RPMs to change the fluid flow at low RPM's and high RPM's. Any excess fluid is diverted back to the pump instead of actually changing the pump turning speed. Like a fuel regulator that can constantly change its psi rating with engine RPM. Haven't figured out how to adapt that to our cars yet.
If you go with a KRC power steering pump you can change the output valve size so the pump flows less gpm, the low RPM turns require a tad more effort but it helps desensitize the high RPM turns which btw should only be in emergency situations. You shouldn't be darting left/right on the highway unless your trying to avoid something.
Personally, highway driving is pleasant, you just have to be careful. 90% of the time your turning at low RPM's so the unit is great.
Old Dec 13, 2007 | 11:52 AM
Mikeg72's Avatar
Mikeg72
Can anyone tell me more about the jeep pump? What year/model jeeps
are these off?
Thanks..
Old Dec 13, 2007 | 04:33 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
are these off?
Thanks..
Not the pump, it's the steering box.
Read post #5. There are lots and lots of threads discussing the jeep box setup in detail.
Old Dec 13, 2007 | 05:44 PM
Bullcrappy1's Avatar
Bullcrappy1
So there is less road "feel".... so a step backwards if your doing some track time, autocross etc? correct?
Is the Jeep box bigger or smaller then stock? ask because of header clearance issues.
thx
rixh
To "jeep" power steering
Old Dec 18, 2007 | 09:08 AM
Mikeg72's Avatar
Mikeg72
Does anyone know if the Grand Cherokee boxes are modified other than the mounting holes? I have one off a 2004 Grand Cherokee and if it's just making mounting plates & positioning holes, I can do that and save myself about $300.00.
Mike
Old Dec 18, 2007 | 11:39 AM
markdtn's Avatar
markdtn
Mike
It's also the Pitman arm and the lower shaft that are modified.
Old Dec 19, 2007 | 04:18 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
An old A-body Pitman will fit, the linkage hole might need to be reamed for the correct size.
