radiator angles
Old Nov 12, 2007 | 12:18 AM
gingerbreadman1977's Avatar
gingerbreadman1977
Default radiator angles
in a c3 what degree does the actual radiator lean back on . if you dont know have a guess but if your 100 % positive please say. im drawing some plans .
Old Nov 12, 2007 | 07:49 AM
babylonvette's Avatar
babylonvette
the nose is off my 72 coupe i will ck it and get back to you it looks like it is about 45% give or take a degree or 2
Old Nov 12, 2007 | 08:32 AM
jnb5101's Avatar
jnb5101
there's a sheet in the aim that indicates a certain gap between the rad and the cross member that determines the lean. i'm at work (physically anyway) and don't have my aim.
jeff
Old Nov 12, 2007 | 08:41 AM
Zychron's Avatar
Zychron
The radiator support in a C3 is leaned back 30 degrees from vertical.
To radiator angles
