Door Panel Srews ????
Old Nov 12, 2007 | 05:08 PM
74LS4vert's Avatar
74LS4vert
4th Gear
Default Door Panel Srews ????
I have a 74 convert with no upper screws or holes in door panels.
Is this unusual ?
Old Nov 12, 2007 | 05:13 PM
Durango_Boy's Avatar
Durango_Boy
Is this unusual ?
Well, yes, as most do by now, there are original trim screws and there are screws stuck through the corners.. There were the two screws that hold in the door pull, there three perimeter screws, , door handle screw, and the plastic Vel-Cro snaps.
Old Nov 12, 2007 | 07:08 PM
68roadster's Avatar
68roadster
My replacement panels from corvette america have no mounting provision at the upper corners. I was thinking some industrial strength velcro might work in these 2 spots
Old Nov 12, 2007 | 07:14 PM
Artsvette73's Avatar
Artsvette73
Take another look from the back side of the pad. They are there
Old Nov 12, 2007 | 07:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sometimes the outer vinyl is folded over the brass bushings, covering them up. They're there, though, and you can feel them through the vinyl.
To Door Panel Srews ????
