Headlight Question
Old Nov 13, 2007 | 08:11 PM
Jon Hekking's Avatar
Jon Hekking
Default Headlight Question
The headlights on my 81 quit coming up tonight. I'm new to headlight issues so thought I would ask for some help. I can't hear any air leaking by the headlights but I do have a new vacuum leak coming from somewhere near the back of the carb. It's too dark and too late to mess with it now. Can anyone tell me where the vacuum for the headlights pulls from? I'll tear into this weekend, just wanted to get some facts to give me a head start.
Thanks in advance........
Old Nov 13, 2007 | 08:21 PM
VeroL81's Avatar
VeroL81
Jon,
Did you have any warning - such as lazy light(s), hissing, switch hard to pull? My '81 suddenly failed, too. My switch got really hard to pull and got to the point I thought I broke it - and then the lights wouldn't come up.
I have a new switch on hand I just need the time to do the install.
...Alan K.
Old Nov 13, 2007 | 08:26 PM
VeroL81's Avatar
VeroL81
In your case that leak in the back of the carb may very well be the culprit. That'll be easy enough to check out.
...Alan K.
Old Nov 13, 2007 | 08:56 PM
Jon Hekking
Noope, no warning, I just turned them on like normal and they came up and went back down.........
Each time I turn them up they come up a little before closing again which is why I'm guessing it's vacuum related.
Old Nov 13, 2007 | 08:58 PM
MakoShark72's Avatar
MakoShark72
May the Force be with you....I'm battling my vacuum system right now. Hope you're a patient man??
Good luck!!!
Old Nov 13, 2007 | 09:03 PM
VeroL81's Avatar
VeroL81
Yup - check that leak behind carb at first light - that's most likely your problem!
Old Nov 14, 2007 | 09:31 AM
saudivette's Avatar
saudivette
IMO, save yourself the grief and expense now and go electric
Vacuum sux
Old Nov 14, 2007 | 09:38 AM
SIXFOOTER's Avatar
SIXFOOTER
To start, fix the leaks anywhere you can hear it sucking. That should get you operational again. Then go thru each hose end to end and make sure they are secure, no problem.
The check valve and filter die on these things, they are located in the vac line behind the carb, replacements are cheap.
Old Nov 14, 2007 | 09:46 AM
VeroL81's Avatar
VeroL81
SIXFOOTER,
Filter? Where? I see a check valve but no filter behind carb. Is there a test for the check valve?
...Alan K.
Old Nov 14, 2007 | 10:44 AM
firefighter's Avatar
firefighter
Vacuum sux
So where do you get the kit to go electric? I looked around at the major vendors and found nothing but that doesn't mean that they don't have it. Thanks in advance.
Or are you talking about getting rid of the popups with the stationary lights?
Old Nov 14, 2007 | 10:52 AM
MakoShark72
Originally Posted by VeroL81
SIXFOOTER,
...Alan K.
Filter is little white circular thing in the line from the manifold. The check valve only flows ONE WAY, towards the manifold. You should be able to blow thru it one way, and one way only...from the side with 2 ports towards the side with one port. Block each of the 2 ports, one at a time, blow thru the other, and make sure each of the 2 ports is open.
Old Nov 14, 2007 | 11:52 AM
...Roger...'s Avatar
...Roger...
http://www.mcspeed.homestead.com/Our_Products.html
Old Nov 14, 2007 | 11:59 AM
saudivette's Avatar
saudivette
No, put electric motors on your pop up's
I've "upgraded" my pop up mechanisms to electric and they work great - you pull the switch and they are UP! Push the switch and you'd better make sure no one has their fingers in the way!
Old Nov 14, 2007 | 03:47 PM
firefighter
Thanks guys I did a hella search and found it looks like that is on the list.
Old Nov 14, 2007 | 04:33 PM
saudivette's Avatar
saudivette
...it looks like that is on the list.
Worth every cent...
To Headlight Question
