Door Pull Question
Old Nov 14, 2007 | 10:08 AM
wjsullivan's Avatar
wjsullivan
Default Door Pull Question
Someone previously replaced the door panels and pulls on my '75 and did a lousy job. The pull doesn't even come close to sitting flush on the car.
What do I need to do to fix this? Or asked another way, what didn't they do to make this look right.
Plus there is that little 'dip' in the top center of the ridge in the door panel.
Are these the wrong panels or pulls?
I know I also need to paint the pull when I get it off. It isn't even close in color.
Old Nov 14, 2007 | 11:02 AM
Durango_Boy's Avatar
Durango_Boy
You will need a long Phillips drive screw driver. It's a large head too if I remember right. Pull the screws out and remove the pulls.
The screw length will be over an inch. Look up inside with a flashlight and you will see the screw holes where the screws go. make sure they are proper sized and not knarled up.
Reinstall the pull, with the screws out, and starting with the top, start the screw. It's hard to start sometimes, and you'll need to go in at an upward angle. Once it's started, do the same with the lower screw.
Because the screws are so long, it takes a while to get them fastened properly, and this is probably where the previous installer stopped.
Be very careful you keep the head square with the driver so you don't strip the screw head. Slow steady turns, and continue until the screw and pull are hard up against the panel.
Once you get one in you'll see how they are supposed to fit.
Old Nov 14, 2007 | 11:25 AM
corvetteload's Avatar
corvetteload
Looks like they are backwards and upside down....................B
Old Nov 14, 2007 | 11:28 AM
pbcanney's Avatar
pbcanney
The pull doen't even look like its in the right car
Durango_Boy
No, I'm sure they are correct. If it were upside down, you would see a screw hole exposed on top.
Old Nov 14, 2007 | 11:30 AM
Vette Crazzy's Avatar
Vette Crazzy
they are definetly on wrong. they are marked left and right
vc
Old Nov 14, 2007 | 11:41 AM
bashcraft's Avatar
bashcraft
vc
They're switched left to right.
Old Nov 14, 2007 | 11:48 AM
Durango_Boy
I didn't even think of being on the wrong door. Hard to tell from that angle. It still looks right though. The upper screw hole is aft of the handle in relation to front and back. In the pic you can see the door handle forward indicating which way is back, and the upper screw hole doe sin fact seem to be facing aft of that.
Old Nov 14, 2007 | 12:05 PM
rihwoods's Avatar
rihwoods
If the screw holes are by chance stripped/pulled out,you can "peen" them flat with a punch....I used teflon tape on screw threads for better grip...
Old Nov 14, 2007 | 12:49 PM
Artsvette73's Avatar
Artsvette73
It's the right handle. If they are replacement door panels the holes are not cut out. The vinyl and the foam needs to be trimmed away so the handle will sit flush to the back of the panel. Use a small razor knife and trim the vinyal and pull out the foam till you see the back panel of the door pad. It looks like this was not done.
To Door Pull Question
