Third Brake Light?
Old Nov 17, 2007 | 11:40 PM
murraybs's Avatar
murraybs
Default Third Brake Light?
I'm paranoid about being rear-ended and was wondering if anyone knew of an aftermarket third brake light for C3s. If there aren't any I can fab one up.
Old Nov 18, 2007 | 12:17 AM
elevatordude's Avatar
elevatordude
Default try this
http://forums.corvetteforum.com/show...rd+brake+light
Old Nov 18, 2007 | 12:22 AM
guitarcrazy02's Avatar
guitarcrazy02
I got rear ended in my 81. It sucked. And I don't think a third brake light makes the other person's brakes work any better.
Old Nov 18, 2007 | 12:42 AM
SEVNT6's Avatar
SEVNT6
I got rear ended in my MR2 which has a third brake light.......
Problem is idiots like this guy never see them when they're punching numbers on their cell phone..........
Old Nov 18, 2007 | 01:04 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
ive seen the tail lights that flash really fast when the brakes are first applied and then they go solid. the quick flashed really get your attention even if you arent looking in the direction you should be. on the other hand i wonder if it could cause someone to have a seizure
Old Nov 18, 2007 | 01:12 AM
LIQUIDDRAGON
well you got me looking and i found this.
http://www.logolites.com/led/third/brake/lights/
Old Nov 18, 2007 | 01:24 AM
LIQUIDDRAGON
still cant find the lights that make the brake lights flash before going solid but i found this as well.
http://www.customdynamics.com/automo...late_frame.htm
Old Nov 18, 2007 | 02:28 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've given a little thought to adding one, C4 ZR1 or std style . Anyone done that?
Old Nov 18, 2007 | 07:18 AM
murraybs's Avatar
murraybs
Hmm none of those really hit me and stand out. I think I'll go ahead and create one for the flat window vettes.
I'll be sure to do a tutorial as well. I'll try and keep some clearance for those of you that have the removable rear window.
Old Nov 18, 2007 | 09:06 AM
Red73's Avatar
Red73
If you look close you can see it at the top of the rear window
Old Nov 18, 2007 | 11:37 AM
vettehed's Avatar
vettehed
The reason the government came up with the upper-center brake light requirement back in the 80's, aka the third brake light, is because crash research suggested that a driver's focus and attention to the car ahead of them is in that area, not where the tail lights are traditionally mounted. Next time you are out driving and are behind someone else, think about where you are focusing...it will be on the passenger cabin/rear window area of the car, not down low where the lights are. The research suggests that because of of the higher and centered mounting location, a driver could/would take notice and react faster to a brake light in this location than they would if it were down low. With the corvette's small dim 2 outboard tail lights, I would think that this could do nothing but help. I am in the process of installing a rear wing on mine and plan to put a led strip in it in addtion to the led lights that I hooked up. All four light up on braking and the outer two on each side blink.
Old Nov 18, 2007 | 12:36 PM
1Z87L8's Avatar
1Z87L8
it was developed for visibility as stated above.
i believe 99% of drivers are looking through the vehicle in front of them
to try and anticipate what their next move will be, cars stopping in front
or weaving to go around an object in the road.
Old Nov 18, 2007 | 12:45 PM
Jims79's Avatar
Jims79
this is a cool 73.. when you chg'ed to the four bubble tail lights why didn't chg to four brake lights? I think four brakes lights would let all know your stopping.....
[/QUOTE]
Old Nov 18, 2007 | 12:49 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
[QUOTE=Jims79;1562803586]this is a cool 73.. when you chg'ed to the bouble tail lights why didn't chg to four brake lights? I think four brakes lights would let all know your stopping.....
There's a winter project for ya' Rod
Old Nov 18, 2007 | 02:50 PM
TPI BOY's Avatar
TPI BOY
I'VE got a c3 roof top one, it follows the
lines of the car and easy install
Old Nov 18, 2007 | 03:29 PM
rudolph schenker's Avatar
rudolph schenker
Any details and pics?
Old Nov 18, 2007 | 03:40 PM
fugawi's Avatar
fugawi
www.billetspecialties.comhas a third brakelight licence plate frame that i use..
To Third Brake Light?
Old Nov 18, 2007 | 03:58 PM
murraybs's Avatar
murraybs
This is almost exactly what I was thinking. Is that custom or was it part of a kit?
Old Nov 18, 2007 | 08:32 PM
gator79's Avatar
gator79
here you go
http://www.webelectricproducts.com/
scroll to the bottom of the page, they also have a sequential turn light module
Old Nov 18, 2007 | 09:04 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
They fit perfect on a C3 roof, I installed one just before our 79 was painted.
