Pulling a 1975 engine
Old Nov 19, 2007 | 09:04 PM
hicswa's Avatar
hicswa
Default Pulling a 1975 engine
Hi,
Come spring I would like to pull the engine out of my 1975 coupe. I was wondering if there are any good books or DVD's out there that could assist me.
Thanks,
Danny
Old Nov 20, 2007 | 11:37 AM
corvetteload's Avatar
corvetteload
Probably not, having the right equipment is essential though, and some mechanical ability. Strip engine as much as you can before pulling, and if an automatic disconnect from block FIRST! Makes it easier to get engine out without massive lift and anglage on the hoist (first hand experience). I then put the chain on the bell of the tranny and hoisted that out. On my 75, the crossmember is removable for the automatic, this helps out too. A lot has to go on to remove an engine, if you never did it before or don't possess the equipment, make some friends who have and do fast....
I just removed the 427 from my 69, took the 4 spd out first and stripped engine down to the block, I was able on my own to pull engine. Car was on ramps all four wheels and picked it right out of there!!! Good luck.......................B
Old Nov 20, 2007 | 11:53 AM
GD70's Avatar
GD70
When I pulled the engine out of my 69 Impala, I took photos and marked every wire and plug with masking tape and drew simple diagrams of where everything connected. Was easy to then put it all back together.
If it's an auto, also remember to disconnect the torque converter from the flywheel before you pull the engine out. Leave the tranny in the car if your only replacing the engine unless you want to clean it up. It's a pretty straight forward job.
Glenn
Old Nov 20, 2007 | 04:09 PM
corvetteload
Glenn,
One thing to remember here, the Vette is not a tank like your Impala, room is a lot tighter and stance a lot lower. One problem I had, at least with my hoist, is that the wheel rails of the hoist hit the a-arms due to the lowness of the Vette. I was working in a tighter space on my 75 than my 69, so I extended the boom and shortened the legs to counter the a-arm dilemma, sucky thing was when I was putting the new motor in, the hoist tipped forward towards the car and the boom hit the firewall. Luckily no damage, maybe a scratch if I remember correctly. So using this knowledge, I put my 69 up on ramps all 4 wheels and since I now had a higher ceiling to deal with it made it a lot nicer, and safer, to pull the block out of my 69. Good thing I pulled it, the pass. motor mount was in 2 pieces and destoyed.
Danny, if you are in or near PA, and you can get the car to me, I'll help you do it, nothing like tearing a car apart!!!!!! (It's the getting back together thing when I lose interest).............Bruce
Old Nov 21, 2007 | 06:47 AM
rustbucket80's Avatar
rustbucket80
Originally Posted by corvetteload
Glenn,
Count me in I'm in Lancaster. I would love to see this done. After Deer season of course
Old Nov 21, 2007 | 08:31 AM
carlthecopyking's Avatar
carlthecopyking
Default Hey Dan I will help You
Dan,
IF you help me put in my antenna.
Carlthecopyking
To Pulling a 1975 engine
