Hey all. Just finished installing my front control arm bushings which all went pretty well. Thought I would share what I did for a press in the cause it may be of use to someone else. Our house has a side entrance alcove which is all concrete. I put down a couple of 6x6 filler blocks and used a 4 ton bottle jack layed on its back to press against the opposite wall. I made up the necessary support pieces as described in the GM manual so as not to damage the arms. I was able to press everything together very slow and controlled (still with caution cause things can always fly apart). All in all not such a bad job except for gettin the spring back in.
I'll post some pics when I get it all together.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Reason: add info
I installed the bushings on my a-arms- luckily only one control arm got bent. It was partially from me, but it was bent a little before hand anyways. I ended up replacing it and instead of risking it in the hydraulic press, I took a different approach. I put the bushing shells in the freezer for a couple of hours before hand and cleaned out the bushing holes on the control arm really good using a dremel tool. I took them out of the freezer and smacked them in with a hammer and appropriate sized socket while my father held the control arm tightly against the workbench. It was still a chore to get them in, but it prevented the control arm from bending. It worked out very well. By the way, good job on the install! I love when people improvise to save money and do the job themselves.
That's a pretty creative solution; I'll have to store that one in my brain-bank, if the beer doesn't flush it out
I did the freezer and hammer thing as well. Scared the crap out of my son who was holding the A-arm though. . . . No problems.
Freezer and hammer worked fine for me. Things became interesting, though, when I realized I had one lower shaft in backwards when I was about halfway done with that arm...
I did that too. Sucked having to remove one of the new bushings to turn the shaft around in the A-arm.
