Fan Shroud options
Old Nov 25, 2007 | 07:26 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Default Fan Shroud options
While pulling the radiator assembly out of my '76, the shroud broke in half with little effort. It was a PITA to get free due to the bolts of the A-ARM.
Not sure if I want to go through putting it back in.
Does anyone here have a custom shroud or not run one at all?
PICS?
Old Nov 25, 2007 | 07:52 PM
Durango_Boy's Avatar
Durango_Boy
When I cut my original shroud out the whole purpose was ease of reinstallation. Seems it happened to you by accident.
If you want it back in, just install it as two pieces again, and I doubt it will go anywhere.
I never did put mine back in. I knew I wanted to go to electric, so I just installed a set of high powered fans to cool the engine, and they have their own much easier install shroud.
Old Nov 25, 2007 | 07:54 PM
Bruthish's Avatar
Bruthish
DB, yeah I like the looks of that. I have been following it through your other posts. I may do the same. Thanks!
Old Nov 26, 2007 | 07:46 AM
markdtn's Avatar
markdtn
I would not leave it out. You are just asking for overheating problems if you do. Due to the slanted nose (and radiator), a C3 needs a shroud worse than most cars.
To Fan Shroud options
