1981 heater blower problem
Nov 29, 2007 | 07:34 PM
Cruising
MY 81 vette blows some air out of the dash, but not nearly enough. The blower is working on all speeds. It seems like something is impedeing the air flow. HELP
Nov 29, 2007 | 07:53 PM
How does it blow out the defroster vents or the floor vent? I have an 81and there's plenty of air from the fan.
Nov 29, 2007 | 08:23 PM
I would check my air ducts behind the dash. A lot of air can be lost thrue those ducts if the're not attached properly.
Just my .02
Nov 29, 2007 | 09:07 PM
agree with RAWJ, probably loose fitting of ductwork, hopefully that's it, no cost just a bit of adjusting, let us know what you find.
Nov 29, 2007 | 10:23 PM
St. Jude Donor '07
Lots of ways to get debris clogging the system. An archives search should turn up all sorts of info on HVAC repairs and improvements.
Dec 1, 2007 | 10:29 AM
Cruising
Quote:
Originally Posted by
Rawj
Just my .02
thanks for suggestion. I'll look and see
Dec 1, 2007 | 10:35 AM
Cruising
Batman, Thanks for the idea. I hadn't thought of that
Dec 1, 2007 | 11:14 AM
Mine had a 1" gap between the air box behind the radio and the duct in the dash, look there
