Painting engine chevy orange
Old Nov 29, 2007 | 08:29 PM
John1973's Avatar
John1973
Default Painting engine chevy orange
What is a good brand of paint to paint the engine chevy orange? Thanks for your help.
Old Nov 29, 2007 | 08:43 PM
Glassbowtie77's Avatar
Glassbowtie77
I used Duplicolor High Temp Chevy Orange on mine and it has held up nicely. The key is make sure that the surface is absolutely 100% clean in order to get good adhesion. http://www.duplicolor.com/products/engine.html
Old Nov 29, 2007 | 08:49 PM
Young69Owner's Avatar
Young69Owner
Ya, good brand. Any AutoZone or similar store will have it. It can handle a lot of heat.
Old Nov 30, 2007 | 07:11 AM
ajstr1265's Avatar
ajstr1265
depending on you level of expertise, I used DuPont Centari, with hardener. It came out looking great
Old Nov 30, 2007 | 07:15 AM
gator79's Avatar
gator79
VHT also makes a good product
Old Nov 30, 2007 | 08:31 AM
jgrigg's Avatar
jgrigg
I used Duplicolor Engine Enamel and it came out very nice.
Old Nov 30, 2007 | 11:52 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
POR-15 chevy Orange.
Old Nov 30, 2007 | 01:02 PM
GD70's Avatar
GD70
I receintly needed to touch up some spots where the paint was lifting above the timing chain cover. I scraped all the loose paint and I used acetone to remove any greece dirt etc... and then sprayed it directly on a small cheap brush. I applied 3-4 coats and it matched the rest of the engine color perfectly.
To Painting engine chevy orange
