Need Steering Wheel Image...
Old Dec 4, 2007 | 06:36 AM
VeroL81's Avatar
VeroL81
Default Need Steering Wheel Image...
Our new steering wheel (leather and mahogony) arrived last night VIA UPS!!
Upon removing the old wheel I found a loose pin lying there - I've no idea where it came from. Also, I thought it strange there was no spring - and the horn does work! Anybody have a good picture of a circa '81 steering wheel assembly - with the hub removed? I saw one about a month ago here - can't seem to find it in the archives.
Thanks in advance - off to work.
...Alan K.
Old Dec 4, 2007 | 09:05 AM
GD70's Avatar
GD70
Do you have the AIM for your tear? That will be the best place to look.
Old Dec 4, 2007 | 09:21 AM
Jim Shea's Avatar
Jim Shea
This is the drawing from the AIM. I don't know if this is what you are looking for. Or if you want a photo.
Jim
Old Dec 4, 2007 | 12:17 PM
VeroL81's Avatar
VeroL81
Jim, Thanks for the response.
That blow-up image doesn't show the pin I'm loooking for. I'm hoping Bubba wasn't in the column doing his repairs and that pin was left over!!
A picture would be great - Thanks!
...Alan K.
Old Dec 4, 2007 | 07:09 PM
VeroL81's Avatar
VeroL81
OK, I installed the new wheel and it looks great - now the horn doesn't work. From the image Jim sent it looks like I may be missing part #4, the insulator.
Sheez - the horn worked before I removed the steering wheel. I made sure I accounted for all the pieces as I took it off - and put everything back the way I found it.
Can anybody explain how the horn works on my '81? Could the problem really be the missing insulator?
Thanks again! ...Alan K.
Old Dec 4, 2007 | 09:32 PM
gator79's Avatar
gator79
the pin you are refering to may be your horn contact
Old Dec 5, 2007 | 08:38 AM
Jim Shea's Avatar
Jim Shea
What are the pin measurements. Or take a picture of the pin next to a ruler or a dime.
Part #3 in the AIM drawing is called the Eyelet may be the pin you are mentioning. The Eyelet has a Spring #2 under it and it is spring loaded up through the Hub Asm and up through all of the steering wheel and telescope parts. It then contacts a stamped L shaped leg on the Contact Asm Upper #7. When you press your horn button (#9, #10, #11) it presses on the Contact Asm. The Contact Asm closes and goes metal to metal providing a ground that closes your horn relay and blows your horn.
If the eyelet was not spring loaded it might or might not reach the leg on the contact asm (depending upon build tolerances.) If it doesn't touch the leg - no horn.
The plastic collar or Insulator #4 holds things together and keeps the eyelet central. Without the insulator the eyelet might touch other metal parts in the steering wheel and hub area. Then your horn will blow continuously.
Jim
Old Dec 5, 2007 | 01:51 PM
VeroL81's Avatar
VeroL81
Jim - Thanks for taking the time to explain.
In checking the drawing again (WITH my glasses on this time) it looks like I installed the Eyelet upside down!!
Gotta try getting home before dark for a change - don't like working under drop lights!
I'll PM to let you know how it turns out.
...Alan K.
To Need Steering Wheel Image...
