Air compressor plumbing
Old Dec 5, 2007 | 03:15 PM
Gordonm's Avatar
Gordonm
Default Air compressor plumbing
I know this had been discussed before I just can't find any good info so I'll ask again. Looking to take my compressor out of the garage and just plumb in the lines to the garage. It will only be carrying max 90 psi and will only have to be about 20 feet of pipe. I am probably going to put in 2 ports one in the front and one at the back of my garage so nothing to fancy. What type of pipe should I use?
Old Dec 5, 2007 | 03:18 PM
Durango_Boy's Avatar
Durango_Boy
Edit - I read to fast. You're speaking of tool compressed air...I was thinking air compressor.
My Step Dad used steel plumbers pipe.
Old Dec 5, 2007 | 03:19 PM
VetteThunder1's Avatar
VetteThunder1
TP Tools and equipment is a good source for the stuff you are looking for, they also have some really good detailed information about plumbing for compressed air.
check out this link, Compressed Air Plumbing Information
Good luck!
Old Dec 5, 2007 | 03:23 PM
1970-Bronze's Avatar
1970-Bronze
I think you will see Black Pipe as the recommended...
Old Dec 5, 2007 | 03:37 PM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
I don't know how recommended this is, but the previous owner of my house had regular PVC pipe run through out the garage. Not sure what pressure it would withstand.
Old Dec 5, 2007 | 03:41 PM
Durango_Boy
It can get fragile with age and when subjected to extreme temperatures and with 90 lbs you could end up with a plastic shard grenade.
Old Dec 5, 2007 | 03:44 PM
Bruthish's Avatar
Bruthish
LOL good to know. That wouldn't be good. i have already removed most of it. I wasn't planning on re-using it. It does break up real nice with a hammer too.
Old Dec 5, 2007 | 04:09 PM
markdtn's Avatar
markdtn
They make special PVC for compressed air use. It is green I think. It is a bit pricey, especially the fittings. I have seen schedule 80 PVC used in many places, but it is not recommended. Pressure is not the problem, but it can splinter like DB said. I would suggest black iron pipe. It is fairly easy to work with.
Old Dec 5, 2007 | 04:12 PM
Gordonm's Avatar
Gordonm
I'll be off to get some black iron pipe and fittings.
Old Dec 5, 2007 | 04:35 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
You can also use copper pipe.
Easier to sweat the fittings together than having to thread a bunch of pipe.
Old Dec 5, 2007 | 04:40 PM
hicswa's Avatar
hicswa
Use copper That all they used at my work. they are using much more PSI than your 90. And it won't rust
Old Dec 5, 2007 | 04:42 PM
bigvette1's Avatar
bigvette1
Take at look at the "Two Guys Garage" site for the Speed Network. They advertise a high tensile strength PVC with quick disconnects for such projects and might be of interest to you.
Old Dec 5, 2007 | 05:06 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I used 1/2" copper, no rust and dissipates the heat from the air quickly to reduce condensation....
Old Dec 5, 2007 | 10:19 PM
spikebot 81's Avatar
spikebot 81
Use copper pipe and fittings. 3/4 main with 1/2 inch outlets. Be sure to put a tee at the end of the line looking down with a valve to blow the water out. Type M copper is more than enough for air line. Rated at 220psi. Burst preasure over 500psi. I am a journeyman plumber 30 yrs in the biz. If you need help soldering I'll walk you through it. It's really very simple. PVC big no no. Mark
Old Dec 6, 2007 | 02:15 AM
rexx78's Avatar
rexx78
First choice would be black pipe with a dryer at the compressor outlet and low point drains. My Dad used copper pipe with no problems for 15 years, but then had a plumber buddy tell him that it wasn't a good idea..? If Spikebot says 500 psi burst pressure, 90 psi should be OK. 4X safety rating... Ask at Home Depot or Lowes, they may be able to give you other options.
Old Dec 6, 2007 | 06:09 AM
Gordonm's Avatar
Gordonm
I guess I'll try copper pipe for ease of installation. I only need about 25 feet total so it is no big plumbing job. I am going to put in a braided flex line from the compressor to the pipe so the vibration does not fatigue the copper. I'll have a water drain at the compressor and at the end of the line. Thanks for the help.
Old Dec 6, 2007 | 07:34 AM
corvetteload's Avatar
corvetteload
copper!!!
To Air compressor plumbing
Old Dec 6, 2007 | 08:40 AM
Durango_Boy
Originally Posted by corvetteload
copper!!!
Too bad the cost of Copper has risen so much and buying it is like buying a small Italian Sports car these days.
Old Dec 6, 2007 | 09:31 PM
...Roger...'s Avatar
...Roger...
At the bottom of each run put in a 12" T water trap.It will save your air tools.
Old Dec 6, 2007 | 11:18 PM
noonie's Avatar
noonie
I used 1" Sch 80 PVC with the good grey glue.
Supporterd every 4ft with clamps and all the water drains and drops etc. Have 6 drops and a 1" flex hose from the compressor to the hard lines.
Been up for 12 years with daily use and @ 125 psi. Never so much as a leak.
The connection from the compressor to the hard line should be flexable to rid vibration, like hose used on a big air jack hammer. Then I would use copper to get into the garage because it can stand a lot of physical abuse and doesn't rust and then inside.... whatever you feel comfortable with.
