Wheel dolly - Any suggestions ?
Old Dec 7, 2007 | 12:29 AM
rajsid's Avatar
rajsid
Default Wheel dolly - Any suggestions ?
I picked up a 69 vette this morning and I am not able to park both my cars in my small 2 car garage.
I am thinking of getting a set of 4 wheel dollies to park one car as close as possible to the garage wall.
I searched online and found this.
Any other suggestions?
BTW.. Here is my new car
Old Dec 7, 2007 | 05:29 AM
corvetteload's Avatar
corvetteload
Harbor Freight sells some
Old Dec 7, 2007 | 09:32 AM
rajsid's Avatar
rajsid
This looks like the best ones that they sell.
http://www.harborfreight.com/cpi/cta...emnumber=38959
Have you used them?
Old Dec 7, 2007 | 09:37 AM
DIPPOLD's Avatar
DIPPOLD
I have had a set of those for the last 2 years they work great. It does take some pushing but then again you are moving a 3Klb car around. I got them from COSTCO for $90 CDN.
Old Dec 7, 2007 | 10:21 AM
L88Plus's Avatar
L88Plus
Harbor Freight runs theirs at $40/pair when they're on sale which is about once a month. I have a couple of sets. Once you get the car moving, they're fine. We spun a Chevelle 180* in my shop last weekend, it rotated like it was on a spindle. If you'll take a minute and get the wheels facing the correct direction, it's a whole lot easier to get 'em going.
Make sure the floor is clean, a pebble or lock washer under one of those steel wheels can be the source of some x-treme language!
Old Dec 7, 2007 | 10:25 AM
Durango_Boy's Avatar
Durango_Boy
Have you used them?
I have a set of those, and they are indeed very hard to move the car when their in use. The reason is because the wheels don't have bearings. Just a pin and nut.
I disassembled all of mine and greased the pins to make it a little easier. The real solution would be to get some with wheels that have bearings in the casters.
If you're under 200 lbs, or have bad knees or bad back, don't bother. You probably won't be able to push them on anything but the expensive ones with good casters.
Old Dec 7, 2007 | 10:33 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
My garage is small and on occasion I need the car against the wall. I use two good quality floor jacks, one under the rear one under the front and it easily rolls sideways....
Old Dec 7, 2007 | 10:47 AM
rajsid's Avatar
rajsid
Yeah, I think the key is to get ones with wheels with bearings.
I am under 200lbs, but I don't have a bad knee.
Here are a few other types that I found.
http://jupetong.blogspot.com/2007/10...ates-with.html
http://www.overstock.com/Home-Garden...6/product.html
http://www.autobodytoolmart.com/pc-1...t-of-four.aspx
http://www.autobodytoolmart.com/pc-1...car-dolly.aspx
http://www.autobodytoolmart.com/pc-1...ler-plate.aspx
http://www.autobodytoolmart.com/pc-1...pair-1572.aspx
http://www.autobodytoolmart.com/pc-1...olly-5000.aspx
Old Dec 7, 2007 | 10:52 AM
tigers123's Avatar
tigers123
My friend bought the harbor freight set and discovered that they did not move to well. He went back and complained to the store and they sold him a better set of casters for 3 dollars a pop. He said it was better than buying some thing he would probably not have used. Now he says they work great. The replacement caster was bigger and the wheel was a hard rubber.
Old Dec 7, 2007 | 11:00 AM
garage-ghost's Avatar
garage-ghost
I have used several of these over the years. Harbor freight ones suck. The best I have found are the #1016-u, 10x16, Upgraded
Caster ones from lakeshorewheelandtire.com $259 set of 4. The trick is the upgrade casters. they have bigger swivel bearings and pin bearings in the wheels.
The pump up ones you have pictured are nice for a quick move BUT you don't want to leave the car sitting on them.
Old Dec 7, 2007 | 11:08 AM
Jims79's Avatar
Jims79
I have a set from Ecklers not sure who makes them (looks like the red ones on this page) anyway paid $139. & they work great. I moved a 4500 lb car around by myself. You may want to check flea-bay for used ones.
Old Dec 7, 2007 | 12:40 PM
rajsid's Avatar
rajsid
flea-bay... How did I forget that.
Do you know if It's OK to leave the car on these for a long time?
BTW.. the Ecklers ones have casters with bearings. They offer free shipping now
http://www.ecklers.com/product.asp?p...9&dept_id=1095
Old Dec 7, 2007 | 02:41 PM
68/70Vette's Avatar
68/70Vette
EAstwood sells the Chinese made dolly and also the USA made models dolleys. I bought their USA made verson (they were more expensive). They look like the red ones shown in the above posting.
Old Dec 7, 2007 | 04:00 PM
Durango_Boy
The only dollies I would leave the car on for long are the curved ones that fit the shape of the tire. Anything that has hard edges or sharp angles don't leave them on for more than a few days. You're next drive would be very bumpy.
Old Dec 7, 2007 | 04:57 PM
rajsid's Avatar
rajsid
I can't disagree with you about that..
Here are the ones that garage-ghost suggested.
http://www.lakeshorewheelandtire.com...olly-buy.shtml
Little pricey (twice as the ecklers one), but looks nice.
Old Dec 7, 2007 | 06:46 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
I have my 72 on a set of these I bought through the internet. It will stay on them all winter. The car does move but it certainly doesn't glide across the garage floor.
Old Dec 7, 2007 | 07:38 PM
rajsid's Avatar
rajsid
The Tire Skate brand has a lot of good reviews. I finally went with them. They claim that their casters are better and bigger than their competitors'.
http://tireskate.com/ts12.php
I bought a set of 4 from eBay for under $200 (shipped)
http://cgi.ebay.com/ebaymotors/4-12-...spagenameZWDVW
To Wheel dolly - Any suggestions ?
Old Dec 7, 2007 | 08:01 PM
1978SA's Avatar
1978SA
The HF ones do take some effort to get rolling, but heck, how often do you move the car?
If it's a daily thing, by all means upgrade, but if it's once a week or more time between moves, just save the money and go with the cheap ones, end result is the same.
Old Dec 7, 2007 | 09:54 PM
VTHokie77Vette's Avatar
VTHokie77Vette
I got some aluminum ones (similar to the ones a few posts up) from Summit Racing. They work great. I can push the car around the garage myself.
Old Dec 8, 2007 | 09:17 AM
harrin's Avatar
harrin
These same ones have worked very well for us
