dumb rotor question
Old Dec 10, 2007 | 08:57 PM
greyghost79's Avatar
greyghost79
Default dumb rotor question
how do you remove the rear rotors on a C3. rivets previously drilled out. thanks for the info.
Old Dec 10, 2007 | 09:07 PM
Scott Marzahl's Avatar
Scott Marzahl
Is the parking brake on? After you remove the calipers, the rotors should slide right off the wheel studs unless the parking brakes are goobered up.
Old Dec 10, 2007 | 09:14 PM
greyghost79
thx
Old Dec 10, 2007 | 10:07 PM
flttester's Avatar
flttester
If that doesn't work, they're rusted stuck. I had to squirt pb blaster where I could (took several applications), then tapped and pried them loose.
To dumb rotor question
