'79 corvette help
Old Dec 11, 2007 | 03:29 PM
papawana's Avatar
papawana
Default '79 corvette help
need the location of the vin number and the two letter transmission code on a '79 vette with the th-350..thank you
Old Dec 13, 2007 | 11:01 AM
papawana's Avatar
papawana
ttt
Old Dec 13, 2007 | 11:19 AM
DINO84's Avatar
DINO84
Vin Should Be On The Left Corner Of The Dash.code Is Mx 1
Old Dec 13, 2007 | 11:36 AM
papawana's Avatar
papawana
maybe I misunderstand your answer...I am talking about the automatic transmission itself...the car's vin number is stamped someplace on it...the two different codes also stamped on the transmission itself for that year car would be either TB or WB...I need to find out where I can look for them on the transmission itself...thank you
Old Dec 13, 2007 | 12:09 PM
Duke94's Avatar
Duke94
Old Dec 13, 2007 | 04:31 PM
papawana's Avatar
papawana
thank you so much Duke...found the date code on the right side of the trans pan, and the factory code on the governor cover...now all I need is where the vin # is stamped on the transmission
Originally Posted by Duke94
Old Dec 13, 2007 | 08:21 PM
Duke94's Avatar
Duke94
Final eight digits of the VIN are stamped into the case on the drivers side flange adjacent to the oil pan.
Old Dec 13, 2007 | 09:20 PM
papawana's Avatar
papawana
found it..thank you so much
To '79 corvette help
