if i install new rotors on the rear of my C3 is it necessary to have them "turned" prior to installation? Is there any preparation at all necessary? I'm installing new pads too. thanks for the info.
I think you can install right out of the box, new rotors & pads. Just clean of the rotor of any dust & when & who did the fronts?
If I ever needed to turn new rotors, they'd be back in the box and back to where I got them.
You should be able to put 'em on and be good to go with a new set of pads. It doesn't hurt to spray them with some brake cleaner at first either to make sure there's no oil or grease on them.
It's one way of correcting runout. It's easier to shim the rotor to get it right, though.
Buy good quality rotors and you shouldn't have to do anything to them. Don't forget, if you turn brand new rotors, you're also reducing their lifespan because that's one less time you will be able to have them turned.
Just wipe 'em off and make sure no grease or oil gets on them. Same with the pads and you'll be fine.
'Tis how the factory did it. They riveted the rotors to the hubs, then turned them as an assembly so the rotor faces were true to the line of rotation.
Packed in the box of AC Delco pads I recently purchased was a note stating'
"Clean rotors with water based cleaner only, do not use brake cleaner products"
Thoughts?
I have always scrubbed with soap and water after turning the rotors.This will remove the tiny micro chips left in the turning grooves that brake cleaner doesnt remove.Once these little metal particles get into the pad surface they just seem to stay there being pressed into the surface as the pad material wears causing brake squeal.
never thought about that, but it makes sense.... Guess I have always been leery of squirting new metal parts with water, but on a rotor it wouldnt matter.
I always cinch them down with a few lug nuts and check the runout. To much and I take them back. A few thou off and I try to shim or may have them cut a little. Over the years the runout has increased to a point where I would not put a rotor on out of the box without checking first.
They can be installed right out of thge box. You will need to check runout. If runout is beyond specs try removing the rotor and rotate it 1 set of lugs, bolt it back up and check it again. Continue this untill you are within specs. Turning the rotor will not correct a runout problem. If you can't get it within specs using the above method you will have to shim it between the rotor and hub flange to correct runout. The new high quality spindles are parallel ground 90 degrees to the centerline to help eliminate this issue but your original GM spindles were riveted to the rotor and turned as a unit to minimize runout. Factory tolerances then were not the best.
My experience with metallic brake pads has been a potential for squealing if you don't scuff the rotors a bit in a multi-directional pattern. Not a problem with organic pads.
