Help on casting codes
Old Dec 11, 2007 | 06:15 PM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Default Help on casting codes
I have gone through a dozen casting code sites but have not found what I'm looking for.
The block is reliably reported to have been bought from GM as a 1970 LS6 4 bolt to be built as a racing engine. The block codes read 3963512 thats the easy one.
What I can't find is: 1) sideways on the bolt flange ( date code) CONV, and 2) above that turned 90% is stamped GM6.
Photo of driver side rear of the block.....thanks Guru's
Old Dec 11, 2007 | 09:30 PM
69 Convertible's Avatar
69 Convertible
3963512 is a 454 with 390hp for 1970, 365 & 425 hp for 1971
Go to corvette-world.com It's been helpful to me. Tony
My bad, didn't read all the way. You looking for the GM6 meaning.
Old Dec 11, 2007 | 09:37 PM
73-84 IMSA Widebody
The front right pad is blank which is expected, block # 3963512 is expected, its the date code "CONV" and the GM6 which I can't find......The block was not Corvette but it and the frame were provided to run IMSA.
After further review "CONV 1"
Old Dec 11, 2007 | 09:49 PM
Mike Ward's Avatar
Mike Ward
GM6 is simply the mold or pattern number the block was cast from at the foundry. Don't know how many molds there were total.
CONV is not a date code, I'll see if I can dig up the meaning
Old Dec 11, 2007 | 10:26 PM
73-84 IMSA Widebody
I found on a site that the CONV was simply a foundry mark.
The date code was on the passenger side rear flange, "j24 0" or Oct. 24, 1970.
If the GM6 is the 6th mold then all questions are answered.
Next one....what is the 020 under the timing chain cover?
Old Dec 11, 2007 | 11:52 PM
LT1driver's Avatar
LT1driver
not sure but the number under timing cover is unimportant ncrs wise. probably more shift/worker/mold etc. marking which most likely never were kept record wise.
Old Dec 12, 2007 | 01:11 AM
73-84 IMSA Widebody
Damn...I just missed her 37th birthday.
I'm now told the 020, and after relooking, 010 means a special casting using 2% more tin and 1% more nickle.
Cool and thanks
To Help on casting codes
