New engine or rebuild?
Old Dec 13, 2007 | 02:05 PM
reidclif's Avatar
reidclif
Proud Hoosier
Default New engine or rebuild?
I recently bought my first Vette, a 1979. The engine runs fine and I was told it was rebuilt about 5,000 miles ago.
I would like to increase the zero to 60 speed (HP?). Should I have the motor rebuilt or go for a all new engine? I have seen some drop-in 350's with 300+ HP for under $5k. I have no idea what it would cost to rebuild.
What are the advantages/disadvantages of both?
Old Dec 13, 2007 | 02:37 PM
Durango_Boy's Avatar
Durango_Boy
Well, there is a lot more involved with 0-60 times than just engine HP. The suspension both front and rear, vehicle weight, gear rations in both the transmission and rear end, and traction via tire selection.
Adding HP can sure be a lot of fun, and doesn't have to be expensive. I think it's more fun to build an engine instead of buying a crate, but at the same time buying a crate is a lot easier and faster.
What's your budget and what would you be looking for if you bought a motor?
You have small blocks, big blocks, stroked engines, forced induction, NOS...and the list of varying cubic inches and sizes just goes and goes and goes.
Old Dec 13, 2007 | 03:57 PM
jonfor's Avatar
jonfor
if the short block is that fresh, i would just look at the top end. heads, cam, intake and exhaust systems. a roller cam would be a good investment.
Old Dec 13, 2007 | 11:43 PM
greyghost79's Avatar
greyghost79
i don't think cams and headers will do much for 0-60 mph times. those mods mainly affect top end. higher differential numbers and a lock up converter will probably be more effective. put some 3.70's in the rear with a 2500 lockup converter and watch the 0-60 drop. obviously the tires have to be good enough to maintain traction.
Old Dec 14, 2007 | 12:43 AM
Bruthish's Avatar
Bruthish
St. Jude Donor '03-'04-'06-'08-'09
Is the motor in question the original Matching numbers? I am going through the same scenerio with my '76. I think I am going to store away the original and find a used 350 as a base and rebuild as I get the time and money.
Old Dec 14, 2007 | 05:38 PM
battjke's Avatar
battjke
Drop in a 383 stroker, change the rear end gears....best bang for the buck.
To New engine or rebuild?
