Mako Shark wheels
But, those aren't what the Mako Shark wheels on my Franklin Mint model look like.
I found these for you. Polish them up & add the knock-off wing center cap..
E-T Aluminum Turbine Mag Wheels, set of 4 15x7.5 Unilug item # 150193454756
Another choice, but also not often seen is the Fenton Fanjet. Someone on here has a set on a blue(?) coupe that looks
You'll also see that wheel in old Motion ads.Happy hunting /:\
[IMG]
[/IMG]
[IMG]
[/IMG]The Western Wheel Turbine Wheel (upper right) actually comes in 7", 8.5", and 10" widths. The 7s have 3-3/4" BS. As I noted, the '82 CE wheel is actually closer to the Mako Shark wheels (in the picture) in that the spokes are straight as opposed to curved, the inserts between the spokes are different, and the centers are different.
I run the 7" Western turbine wheels with "fake" spinners and cones on my '64. Note that the turbine wheels have 30 spokes (as opposed to Corvette knock-offs/bolt-ons with 36 spokes. Also note that these fit Chevy/Ford/Chrysler due to the slotted lug holes.
As I noted, although certainly different, the 8-inch wide '82 CE wheels (with added dummy spinners, as opposed to 6"-wide midyear knock-off/bolt-on) wheels are probably as close as you will get (without going custom).
My way was cheaper, easier, and all parts are still available. These parts are available though Custom Wheel Accessories in Anaheim, CA, as well as other wheel part outlets.
"Hat" (tower) is #13. Cone is #19.
Spinner is #40. Spinners come in left and right. I got two of each, but the left ones would not fit properly over the hats (from a different mfg I guess). CWA swapped out the two lefts that didn't fit (even though I totally butchered one trying to make it fit) for two more rights that do fit and gave me a couple extra emblems for if I do find a pair of lefts that will fit. I know they exist, because I my old pair of lefts fit the new hats (but are quite pitted).
Emblem is 0923.
Including new lug nuts, you can do this conversion for well under $50/wheel.
You can still pick up a set of the Western Wheel turbine wheels for $100-200/set of four. They come in 7" (for mid-years), 8.5" (for C3s), and 10" widths (for custom) and fit Chevy/Ford/Chrysler. (I paid $80 for my four and have a couple extras for drag racing and "just in case" at $20/each.)
Not sure how you figure your way is cheaper either. Anybody with a lathe can make the adapters from the magazine article in a few hours. Then all you have to buy is the cones and spinners. Don't need to buy lug nuts or hats like your way.
Not sure how you figure your way is cheaper either. Anybody with a lathe can make the adapters from the magazine article in a few hours. Then all you have to buy is the cones and spinners. Don't need to buy lug nuts or hats like your way.My way has been documented many times on the Corvette Forum. Not my fault you didn't follow the threads.
I don't see how you can say that obtaining the proper piece of aluminum, accessing a lathe, having the skills to turn it a lathe, buying the Allen screws, drilling and tapping the lathed piece to accept the screws, etc. is cheaper than spending <$10 for ready made hats that simply bolt on.
And no, you don't need new lug nuts and the old scarred ones don't even show under the cones.
You guys seem to take your wheels VERY seriously! You each have excellent info there's no doubt about that!
As a new member, I'm just glad I could ask either of you guys a question and know that I'll get supurb advice!
I think you guys are great and I just have stock wheels!
I have one question though, I wonder if Kid Vettes' Dad could beat up Toddalins' Dad! LOL!
Drive safe!
MK
