Idiots tips for removing / installing a new engine
Old Dec 22, 2007 | 07:33 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I found this book quite useful
Old Dec 22, 2007 | 09:25 PM
PeteZO6's Avatar
PeteZO6
cduemig,
Great post! It brought back memories of me when I was about your age and in the Air Force, nearly 50 years ago. I had to overhaul the engine in my first car, not a Corvette, but a Jaguar XK120 http://www.myruffhouse.com/xk_120_jaguar.htm. The problems I encountered were different in detail but the same in that I learned as I went along. Definitely remove the battery cable before doing any work like removing an engine, I sure learned that the hard way.
Cheers and the best to you!
Pete
Old Dec 22, 2007 | 11:12 PM
cduemig's Avatar
cduemig
I drove my car for the first time since my install. She drove great! I'm so happy. The trans shifted a little late, maybe do to different vacuum, but it has been drained for some time and it may be a little low on fluid now. I hooked up my exhaust today and didn't have the clamps on tight enough and smoked out the garage. It was choking me
Thanks guys for all the support. Perhaps I should reorganize my thoughts and write out a whole organized process.
Old Jul 9, 2008 | 12:35 AM
cduemig's Avatar
cduemig
I've got another big one...
When installing the modulator back into the trans, I used the wrong bracket. I have no idea what that bracket was for and it was a little weird putting it on, but it did work. Needless to say the modulator popped out while driving kicking it into neutral. I refilled and replaced the modulator (which was lost) and she shifted from first to second, but not third. It also didn't shift into first from N as firmly. I thought the pump may be going. I took it to a trans shop hoping it was in the valve body and they said I needed a full rebuild. Thanks to a forum member, I found out there's a modulator valve behind the modulator that also popped out which was the whole problem. Soo, don't do that
Old Oct 8, 2008 | 11:22 PM
offroadtoyota's Avatar
offroadtoyota
Good post! I had fond memories of forgetting to cap off oil lines.
