which oil and filter do you prefer??
Old Dec 18, 2007 | 05:00 PM
LT1driver's Avatar
LT1driver
Default which oil and filter do you prefer??
which oil and filter would you use for a daily driver using conventional oil
looking at the following for a daily driver: castrol gtx
quaker state
Filters: STP, delco, bosch, motorcraft, or fram
autozone has sale and those are my choices, 350 motor with auto/air.
thanks for imput
Old Dec 18, 2007 | 05:10 PM
Bowerss2's Avatar
Bowerss2
I use fram tough guard
Old Dec 18, 2007 | 05:12 PM
75 Red Vert's Avatar
75 Red Vert
Castrol GTX & a K&N Oil Filter - Autozone should have a K&N oil filter, but it may not be for sale.
Old Dec 18, 2007 | 05:15 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I always use Quaker State 10W30 and have a stock of ACDelco PF25 filters.
Old Dec 18, 2007 | 05:18 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Mobil1 and Purolator Pure One.
Old Dec 18, 2007 | 05:43 PM
Glassbowtie77's Avatar
Glassbowtie77
Valvoline Maxlife Synthetic Blend 10w30, Fram Tough Guard or Napa Gold (Wix) filter.
Old Dec 18, 2007 | 07:22 PM
Surfer69's Avatar
Surfer69
K&N 2002 Valvoline VR1
Old Dec 18, 2007 | 07:31 PM
nutsy's Avatar
nutsy
Fram With Rotella 15 40.
Old Dec 18, 2007 | 07:59 PM
1972warship's Avatar
1972warship
Mobil 1 and Mobil 1
Old Dec 18, 2007 | 08:03 PM
68AIR's Avatar
68AIR
Rotella T 15W-40 with a PF25 filter
Old Dec 18, 2007 | 08:21 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
AC Delco, use the long PF35 or 1218. Penzoil synthetic 10-30w oil. I always switch to syn oil after the engine has about 30,000 miles on it. Keeps the engine clean as the day it was built.
Old Dec 18, 2007 | 08:35 PM
Derby98's Avatar
Derby98
St. Jude Donor '09
Rotella 15W40 & Wix
Old Dec 18, 2007 | 08:53 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Derby98
Rotella 15W40 & Wix
Same here. Wix or Napa Gold and Rotella in the 70. Any of my newer cars, Mobil 1 and Wix.
Old Dec 18, 2007 | 09:10 PM
rcread's Avatar
rcread
I completely agree with the NAPA Gold/Wix filter. Avoid Fram at all costs. They've twice left my garage floor coated in oil due to defects.
Old Dec 18, 2007 | 09:16 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Castrol GTX and Fram oil filters
Old Dec 18, 2007 | 09:26 PM
markdtn's Avatar
markdtn
Valvoline oil and Wix or Delco filters
Old Dec 18, 2007 | 09:47 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
AC Delco and Castrol
To which oil and filter do you prefer??
Old Dec 18, 2007 | 10:15 PM
stock76's Avatar
stock76
Check out this link: http://minimopar.knizefamily.net/oilfilterstudy.html. It's a real eye opener.
I currently use Mobil1 20w50 and Purolator Pure One filters.
Castol has just introduced a new 20w50 full synthetic with a zinc rich additive package formulated specifically for classic cars. the info is on their website. Not recommended for C-3s with catalytic converters. I think I am going to give that a try on the next oil change. Sounds like the best of both worlds. Staying with Puroulator on filters though. Them or Wix.
Old Dec 18, 2007 | 10:25 PM
dmaaero's Avatar
dmaaero
Rotella for my flat tappet cam, and wix or pure one filters.
Old Dec 18, 2007 | 10:29 PM
BigBlockTank's Avatar
BigBlockTank
We can tell you any oil, but you need to research and find what you want and like. Look at oils that have the correct additives for a flat tappet cam. That's what all this is about, really. If you have a roller ,motor, you can use whatever you want. Rotella has the additives, Valvoline VR1 has the additives also. Most any "racing oil" will have the additives needed for a flat tappet cam. Tank
