Well my 5 speed OD trans install is almost complete, it is down to the clutch pedal linkage and spedo connecting. I have modded the original t shift handle to come up in the original shifter location so no one will even notice that it is not original. I picked up the new shift plate I had made today made of stainless steel etched to have the shift pattern raised and polished with a gloss black background just like the original. So far I have $700 in the change over. The trans is out of a Toyota turbo pickup and looks like a TKO gear box. The neat part is the pilot shaft is nearly the same length as the 4 speed and the original throw out bearing fits perfect.
Dean, you got my attention More info needed, did I miss a previous thread? Did it bolt up to the existing bell housing, How long was the tail shaft, did you need to re size the drive shaft, What are the gear ratios, Is that go-kart tranny going to hold up to hallin your azz
Need pics
Bullshark
Oh Yeh, Did you have to cut the crossmember to get it in?
Need pics
Bullshark
First off the 81 has a bolt in cross-member and all I did was cutoff the trans mound bracket and weld in a new steel bracket to beable to use the truck trans mount. I had a steel adapter machined to bolt to the original bell housing also had a new pilot bushing machined. There was no tunnel mods needed and a new drive shaft leaving the truck yoke out a little in order to be able to disconnect the u joint and slide in to remove the shaft and not need to remove the rear pumpkin. This trans is a really big unit almost double the size of my 4 speed. It looks just like the TKO trans. As for the gear ratio I have no way to tell but I do understand the OD is .82.
I did cut the floor to make a new hole for the shifter.
I will try to get some pictures this weekend and post them.
Bill I think I covered everything in my original post. but bell housing, flywheel, pressure plate, throw out bearing and fork are original 4 speed. you can see the adapter between the trans and the bell housing.
Originally Posted by dmaaero
The maid sure does a nice job of keeping it clean under there !
I do keep her busy
