Help with TH400 removal...
Old Dec 21, 2007 | 03:02 PM
MakoShark72's Avatar
MakoShark72
Default Help with TH400 removal...
Got the fluid drained..thanks guys!
TWO questions..
1. Cant get the upper fluid pipe off. The 1/2" fitting seems to be a bit rounded off, and I cant get small vice grips up in there to break it loose (no room). Any ideas?
2. I have a removable cross member. Should I (or do I NEED to) remove it if I plan to take the engine and tranny out together??
I could always cut the metal pipe if I cant get the fitting loose, then have new ones made up here, I suppose.
Thanks!
Old Dec 21, 2007 | 04:34 PM
halfmoontrail's Avatar
halfmoontrail
Try Nut Buster Wrench after a lot of PB blaster.
Removing the x-member will give the engine/trans more fredeom of movement, but it doesn't have to come out.
Steve
PS: Go ahead and trash the cooling line, and call Inline Tube for new ones.
Old Dec 21, 2007 | 04:45 PM
MakoShark72
Problem is clearance. I may lower the tranny slightly to get to it, but will probably get some stainless lines made up here locally.
Thanks!
Old Dec 21, 2007 | 04:56 PM
halfmoontrail
saw it off, remove fitting after engine/trans are out.
I wouldn't recommend stainless for these, it is already difficult to get them to seal, and stainless is so hard, very difficult to get a good seal on the seat.
Good luck
To Help with TH400 removal...
