rim cleaning
Old Dec 23, 2007 | 11:40 PM
the other dj's Avatar
the other dj
8th Gear
Default rim cleaning
so im refurbing an old vette slowly but surely..see previous thread
http://forums.corvetteforum.com/show....php?t=1850881
and now i have some questions about the rims as i took them off the chasis to have a proper look at whats what under there, is there an way i can get rid of this pitting on the rims, does it necessarily require beadblasting?, id rather use some elbow grease than anything but what do you lot reccomend?
thanks
Old Dec 24, 2007 | 12:42 AM
Tony24's Avatar
Tony24
Default Blasting
I have seen soda blasting with zero harm to Aluminum. The demo was on a soda can, it took the paint off the can with zero harm to the Aluminum. No marks or tiny pits what so ever. The can even had a high gloss after the blasting.
Old Dec 24, 2007 | 01:03 AM
RIJVETTES's Avatar
RIJVETTES
Blasting would be best for all the nooks and crannies. But If you prefer elbow grease, then try a mild solvent or cleaner and experiment with different grades of steel wool.
Old Dec 24, 2007 | 01:21 AM
Tony24's Avatar
Tony24
RIJVETTES - Do you think a mild compoud would work?
Old Dec 24, 2007 | 03:14 AM
str8upchevy's Avatar
str8upchevy
From: 90% of all Fords are still on the road.....the other 10% actually made it home!
I just picked up a '79 Chev SWB last month and it had a set of Centerlines on it that were all pitted and rusted and wouldn't come clean.
What I always do with wheels like this is buy the Eagle One "MAG" cleaner.
(It says not to use on Polished wheels, but I've used it on 3 different sets of Polished Auto Drags and then just polished them back to a shine without any problems at all)
Anyway, this is what my wheels looked like before the Eagle One.
BEFORE
DURING.........sprayed it on & scrubbed it with a toothbrush!
AFTER........they went from pitted to this for only 6 bucks!
They're way more shiny than that since I polished them up with "Mothers",......I just don't have any pictures yet.
Old Dec 24, 2007 | 09:08 AM
the other dj
8th Gear
you have my attention
great advice guys, ill give this mag cleaner a try out and see how it looks, if all else fails i guess i can get them blasted - thanks so much!
Old Dec 24, 2007 | 09:28 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
they make an acid that works on aluminum also, spray it on and hose it off. I forget what type acid tho... used to use it on the old Keystone slotted wheels back in the 70's and 80's.
To rim cleaning
