Engine bay after 1st cleaning...pics
Old Dec 28, 2007 | 11:00 PM
Tony24's Avatar
Tony24
Default Factory
Hi Guy's, is the POR - 15 brand the closest to factory color you know of? Or it just a rust killer.
Old Dec 29, 2007 | 12:15 AM
MakoShark72's Avatar
MakoShark72
Tony,
Dont know about closeness to factory, I'm after protection. Maybe somebody else will chime in.
Old Dec 29, 2007 | 01:15 AM
saudivette's Avatar
saudivette
Originally Posted by den(thevetteman)78
...I was considering powder coating all my small parts. Is the small kit from Eastwood is good. And is it easy to work with that kind of method. I just want to have the best thing i could get for my $. I can't afford to do it twice.
Yes, the Eastwood kit is pretty good - that's what I use. Be warned though, powder coating is a disease! You'll actually go HUNTING for things to powder coat. I did my distributor and wiper motor yesterday
Old Dec 29, 2007 | 01:17 AM
MakoShark72
How much is the kit???
Old Dec 29, 2007 | 01:36 AM
saudivette's Avatar
saudivette
$89.99 at the moment
Old Dec 29, 2007 | 02:45 AM
MakoShark72
So basically..hows it work?? I went to their website and saw a gun for $99, but the "system" started around $700!! I am sure you need more than just the gun???
Old Dec 29, 2007 | 04:22 AM
saudivette's Avatar
saudivette
$99 gets you a hobby gun, which is all you'd need to get started and then buy the powder colours that you want. $700 gets you a pro gun and a load of other stuff that you don't necessarily need.
Real simply, powder coat is powdered plastic. The gun is attached to a power box and there's also a ground lead. You put the ground lead on your piece then spray the powder at it. As the powder comes out of the gun, it picks up a static charge (can't remember if pos or neg) then it is attracted to your piece and "sticks" there. Then you put it in the over and bake it.
Old Dec 29, 2007 | 11:55 AM
den(thevetteman)78's Avatar
den(thevetteman)78
I was thinking of getting the deluxe gun kit at $139.99. How much can you paint with a 1/2 lb container of paint? Does they come with instruction?
Old Dec 29, 2007 | 04:15 PM
saudivette's Avatar
saudivette
You'd do a fair bit with 1/2lb of powder, probably 4 or 5 largish items like alternator, power steering pump, master cylinder etc. Just a guess though. And yes, they come with basic instructions but there's plenty of help available...
Old Dec 29, 2007 | 06:24 PM
Edzred72's Avatar
Edzred72
No where near factory. Comes in semi gloss or gloss. POR is one of the best rust preventive coatings out there. I topcoated my POR painted frame with Chassis Black to resemble original.
Eddie
Old Jan 29, 2008 | 01:56 PM
ace_cobra's Avatar
ace_cobra
i used a pneumatic grinder w/ wire wheel, laquer thinner and ALOT of scotch brite, and also about 12 hours prepping the engine bay. Then all i sed in tremclad semigloss black(or rustoleum) and i turned out much better than i expected. Cheap too, only cost me about 5 bucks for a pint(x2) and 7 bucks for laquer thinner(x2) bringing a grand total of about 25 bucks.What do you think?
Old Jan 29, 2008 | 02:43 PM
spedaleden's Avatar
spedaleden
I'm looking at your avitar and that pic is beautiful and I was wondering why you stripped it. Is the avitar not your car?
Old Jan 29, 2008 | 03:04 PM
  #33
MakoShark72
Dennis,
If the ? is directed at me, nope its not...Its my MOTIVATION!!! Its an Ontario Orange 72, like mine was originally...Mine had been repainted, etc....thats why I've stripped it down to parade rest!!
Old Jan 29, 2008 | 03:10 PM
  #34
spedaleden's Avatar
spedaleden
Dennis,
OK, I'm up to speed now. Your car is going to be sweet once it's done
Old Jan 29, 2008 | 03:20 PM
  #35
MakoShark72
Dont know if youve been following along..but..
ZZ4
2004R
Hooker chrome 4" sidepipes
Vintage Air
Dewitt radiator
L88 hood
VBP suspension
VBP brakes
Ansen slotted dish rims
New Deluxe (sort of) interior..minus the woodgrain
Probably Atomic Orange w/ black stripe, maybe similar to Skunks design??
etc,etc,etc
Maybe by this summer???
Old Jan 29, 2008 | 04:51 PM
  #36
wro87's Avatar
wro87
Just how tuff to install the poly bushings and any suggestions or warnings. We are getting ready to do it also and I hope our front end comes out as nice. Thanks wro87
Old Jan 29, 2008 | 04:57 PM
  #37
saudivette's Avatar
saudivette
Originally Posted by ace_cobra
...Then all i sed in tremclad semigloss black(or rustoleum) and i turned out much better than i expected. Cheap too, only cost me about 5 bucks for a pint(x2) and 7 bucks for laquer thinner(x2) bringing a grand total of about 25 bucks.What do you think?
Looks good. Was the paint brushed on or sprayed?
Old Jan 29, 2008 | 05:11 PM
  #38
MakoShark72
Various methods to get the old ones out. I burned mine, others have used a hole saw... I think if I ever had to do it again, I'd run the A arms and trailing arms down to a local NAPA and have the old ones pressed out and the new polys pressed in. Save SO MUCH time and its easy to "deform" the ends of the TA and A arms where the bushings go, especially if you use a BFH to knock out the old ones. You can use the time cleaning, etc...Overall not a tuff job to do, just can be nasty, esp if you burn out the old ones..Also, lubricate the polys WELL or they will squeak...forget what I used but I'll research it...
The lube is Formula Five, made by Energy Suspensions...got it at Napa...
Old Jan 30, 2008 | 12:20 AM
  #39
ace_cobra's Avatar
ace_cobra
i used a spray gun to paint it, worked out beatifully
