Brake Bleeders
Old Dec 28, 2007 | 02:00 AM
Recon12thman's Avatar
Recon12thman
Default Brake Bleeders
Has anyone ever put on a performance bleeder from earls or such and if they did what size is it
Old Dec 28, 2007 | 09:27 AM
Durango_Boy's Avatar
Durango_Boy
I just buy the check valve bleeder screws at Autozone and install them in my calipers. I think they are like $7 for a pair, and I bought enough to replace every bleeder screw on the car. They made bleeding a snap with one person.
Old Dec 28, 2007 | 09:57 AM
Merlinhaggard's Avatar
Merlinhaggard
Seems like I remember them being about 15.00 per caliper. They didnt work for me at all.. Dissapointment..
Old Dec 28, 2007 | 12:42 PM
Recon12thman
yea i just want something thatll make bleeding easy
Old Dec 28, 2007 | 12:54 PM
rcread's Avatar
rcread
I'd always gravity bled, which works great if you are very patient. For the last go-around, I bought a Motive Products pressure bleeder. I'm a big fan. I had to use a c-clamp to get a good seal on the master cylinder, but once I did, it was a breeze.
Old Dec 28, 2007 | 01:18 PM
75 Red Vert's Avatar
75 Red Vert
I used the speed bleeders from O'Reilly's and they worked just fine for me. My wife doesn't like to hear, "Push" "Let up" a hundred times "in the garage".
Old Dec 28, 2007 | 02:25 PM
stingr69's Avatar
stingr69
Get the Motive Products pressure bleeder and a big C-Clamp from Harbour Freight. Trust us on this or you will struggle for DAYS!!!
-Mark.
Old Dec 28, 2007 | 02:35 PM
coinwasher's Avatar
coinwasher
-Mark.
It's a breeze with a power bleeder, C clamp is a must.
Old Dec 28, 2007 | 02:41 PM
Chris Farrer's Avatar
Chris Farrer
Silly question I have power bleeder that has the chain but what does the C Clamp look like please.
Old Dec 28, 2007 | 02:50 PM
rcread's Avatar
rcread
Just a big c clamp that you get at the hardware store. Like this...
I put a board on top of the Motive Products piece that goes on top of the master cylinder, and then use the clamp to hold it tight. It works much better than the little chains they give you.
Old Dec 28, 2007 | 02:57 PM
Chris Farrer
Good idea thank you
To Brake Bleeders
