windshield wipers not working...
Old Dec 29, 2007 | 03:45 PM
pbrstreetgang's Avatar
pbrstreetgang
Default windshield wipers not working...
What is the main thing that goes wrong with wipers on Vettes? Since mine is soon to become a DD I'd like to get 'em workin'. Any suggestions?
Old Dec 29, 2007 | 04:00 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Mine werent working for some time and I was tired of checking everything just to find it right, it turned to be the negative route wasnt connecting to the chasis on the switch side in the center console.
Old Dec 29, 2007 | 05:11 PM
BigBlockTank's Avatar
BigBlockTank
Mine were inop when I bought it too. I had some charred wires, vacuum hoses misrouted, burned up motor. Take the time to diagnose all the parts involved, wiper switch, service valve, wiper motor, fuses, and vacuum lines. You can start at any point, just check them all. I got my wiper door to move last night for the first time. Hope you find and fix the problem.
Old Dec 29, 2007 | 09:43 PM
dmayhew's Avatar
dmayhew
Default What year model car?
The answer to your question will depend on rather you have a 68 thru 72 or a 73 thru 82
David
Old Dec 30, 2007 | 01:08 AM
pbrstreetgang
It's an '80.
Old Dec 30, 2007 | 01:09 AM
Tony24's Avatar
Tony24
What year is your Vette?
Old Dec 30, 2007 | 01:16 PM
dalewilson99's Avatar
dalewilson99
OK what have you checked so far? What are the symptoms? Do the wipers work at all, do they sometimes work, do they stop at random times?
First if you have not done so already, check the fuse, check the connections at the wiper motor(2 plugs,1 ground) , at the wiper controller(1plug) located under the aux box in the back, the ground connection for the wiper motor on the bell housing, the connections(2 plugs) at the wiper switch.
Cheers
Dale
Old Jan 2, 2008 | 10:16 PM
pbrstreetgang
I checked all the connections and the fuse. All seemed good. I'm thinking the motor itself may be bad. I noticed when I flipped the switch a ticking noise came from the wiper motor assembly. It kinda sounded like something was stripped. It only did it a couple times then stopped.
Old Jan 2, 2008 | 10:31 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
Rain-x
Old Jan 3, 2008 | 12:53 AM
rihwoods's Avatar
rihwoods
Exactly what mine are doing on my 69...just click click click...wiper door opens though....
I have not got into mine yet...we are in a drought...
Your 80 sounds like maybe the resister or switch deal like my 78...more complicated....I'm down to one speed in that turkey...if I giggle the switch...
Rich
Old Jan 4, 2008 | 12:13 AM
dalewilson99
If you want to test the wiper motor try this, at least for the 78 to 82.
The connector for the wiper motor should have 3 wires. Purple(top),White(middle),Gray(bottom). The wiper motor cover should have 2 wires Black, Pink.
Make sure the black wire goes to ground. disconnect the 3 wire connector and supply 12 volts to the center connection on the motor where the white wire would go. ground the purple and gray connections on the motor. Wipers should run in slow speed.
Open the gray(bottom) connection. Wipers should run in high speed.
Ground the gray connection and open the purple(top) connection. Wipers should park.
To windshield wipers not working...
