ride height
Old Dec 29, 2007 | 08:43 PM
edmontonvetteguy's Avatar
edmontonvetteguy
2nd Gear
Default ride height
I have a 78 vette that I have been doing a frame off for several years now. The suspension is back on as is the body and engine etc, but the distance between the tires and the bottom of the fender wells is about 6" front and back. front and rear springs are original but have been powder coated. Could that change the tension of the springs or not? what am I missing?
Old Dec 30, 2007 | 08:46 AM
fugawi's Avatar
fugawi
can you move it enough to let the suspension settle? you need to get it to settle .. roll it around your driveway..
Old Dec 30, 2007 | 09:27 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
The primary factory trim heights for the '78 are as follows...
...curb weight being as built w/coolant and fuel to capacity.
Old Dec 31, 2007 | 10:49 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
SkunkWorks, thanks for the drawing. Am soon picking up a 78 and am needing to know the height of the door bottom to see if it will clear the trailer fender or if I'll need to roll it up on to some 2x12 blocks.
How much higher is the door bottom edge from the body? Thanks
Old Dec 31, 2007 | 06:19 PM
edmontonvetteguy
2nd Gear
will try that. Thanks
To ride height
