seat angle
Old Dec 31, 2007 | 10:28 AM
vette666981's Avatar
vette666981
5th Gear
Default seat angle
New to the forum here. On and 81, passenger seat... is there a way to adjust the angle of the seat back? My wife complains that it feels like it is reclined. I unbolted the back 2 bolts and put some washers in. It helped some but is there anything else I can do? Thanks, J
Old Dec 31, 2007 | 10:35 AM
red topless gator's Avatar
red topless gator
I took a small towel, the same color as the seat, rolled it up and put it under the back, helps a lot...............LT
Old Dec 31, 2007 | 11:33 AM
C3 Stroker's Avatar
C3 Stroker
There is a shim kit (washers and spacers) for 68-75's which works well on my '69, but I'm not sure if the seat backs are similar on an '81....see this link:
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
http://www.parts123.com/parts123/yb....0g~Z5Z5Z5GAXJU
Old Dec 31, 2007 | 11:59 AM
vette666981
5th Gear
yeah, we use the towel trick now. I was hoping for something more permanant. thanks
Old Dec 31, 2007 | 12:00 PM
vette666981
5th Gear
thanks for the links. I'll check it out.
Old Dec 31, 2007 | 01:08 PM
Edzred72's Avatar
Edzred72
Don't know about 81's...but on earlier C-3's you must be carefull not to shim the seatback up too much. The seat back lock may not catch.
A 1" thick piece of aluminum stock...drilled, sanded & painted makes a great spacer between the seatback strap mount & lower seat. Seatback bumpers can now be shimmed safely to a more upright position.
That's what I did to mine, so that this "short" guy can see over the dash....
Eddie
Old Dec 31, 2007 | 01:17 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I took two pieces of heater hose (5/8), slit it on one side and snaped it over the clamshell seat. One on the seat part and one on the back part. Worked like a charm. Moved the seat-back up about an inch and now the wife will ride in the car. This is about the easiest and cheapest way to fix this problem.
Dave
Old Jan 1, 2008 | 10:29 AM
vette666981
5th Gear
thanks Eddie. My side is no problem(power seat) just passengers. Jeff
Old Jan 1, 2008 | 10:31 AM
vette666981
5th Gear
Thanks, Dave, that might be a simple solution. Jeff
To seat angle
