Valve Cover Dimensions
Old Jan 4, 2008 | 08:53 PM
wjsullivan's Avatar
wjsullivan
Default Valve Cover Dimensions
I picked up a couple of '70's'ish chevy valve covers locally for cheap as I need to replace the ones on my '75 350 and figured I could take a shot on these 'blind'.
What are the dimensions for the standard 350 valve covers? I haven't taken the old ones off yet and they are tall covers, which I don't think I need on my stock '75. I want to make sure these aren't too small or short.
Old Jan 6, 2008 | 03:35 PM
wjsullivan's Avatar
wjsullivan
Come on somebody has to know the dimensions or how to identify if these covers will fit my 350.
Old Jan 6, 2008 | 06:37 PM
DZRick's Avatar
DZRick
Do you just need a measurement from the gasket flange up into the cover?
If what you bought are stock 7 finned aluminum and your running stock rocker arm you should be fine.
Old Jan 6, 2008 | 07:28 PM
wjsullivan's Avatar
wjsullivan
All three dimensions would be preferable.
Length, width and inside height.
Old Jan 6, 2008 | 11:03 PM
SEVNT6's Avatar
SEVNT6
Length & width will be the same as your stock covers. I have the stock aluminum covers DZRick mentions and from the top of the flange to the top of the cover it's about 2 5/8"...
To Valve Cover Dimensions
