Trans line Help Needed (Pic)
Old Jan 6, 2008 | 05:59 PM
Emeightch's Avatar
Emeightch
Default Trans line Help Needed (Pic)
I bought a new set of ss lines from In-Line Tube but they do not match up with what I took off.
Please take a look at the pick, it looks like the old ones were spliced and the portion going into the radiator is a positive screw-in type. The new ones stop short and it looks like a rubber line needs to be added to continue them to the radiator. If so, I probably need to find a nipple or something that stick out of the radiator and downward to the new lines, right?
http://i96.photobucket.com/albums/l1...h/DSC01440.jpg
If anyone has any pics of thier routing, I would greatly appreciate it! Man am I glad I've been keeping the old parts as I go...
Old Jan 6, 2008 | 07:35 PM
c3corvette77's Avatar
c3corvette77
i don't have any pics of it but i have rubber hose going the last 6 inches or so from the hard lines for the trans on the frame to the hard lines coming out of the radiator on my '77.
Old Jan 6, 2008 | 07:40 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Same on my 81 and 73. i believe that it should not be hard line all the way to the rad. there should be a short (6 inch) piece of tubing separating the rad and the end of the hard tubing.
Old Jan 6, 2008 | 07:48 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Same on my 78. Believe it so that vibration and twisting doesnt rip or crack the steel line. The rubber allows it to flex a little.
Old Jan 6, 2008 | 08:01 PM
noonie's Avatar
noonie
The ones that go on the rad are just very short tubes with a bead on the open end just like the ends on the new ones you got.
Old Jan 7, 2008 | 12:09 PM
Emeightch's Avatar
Emeightch
Thanks!
I wonder why they didn't give me the other tubes coming out of the radiator.
Old Jan 7, 2008 | 01:08 PM
Scott Marzahl's Avatar
Scott Marzahl
I've found that most catalogs list the two adapters for the radiator seperately from the main lines.
Old Jan 7, 2008 | 01:56 PM
69monzacpe's Avatar
69monzacpe
My '69 also has the short rubber sections.
When I replaced mine, I just went to my local APCO and bought straight tubing and bent it myself. I already had a tube bender from previous jobs, so this was a "cost effective" solution for me. I just used the old tubes as guides to bend the new tubes. Also, I think I just re-used the short pieces that screw into the radiator. Unless they are just really buggered up, they can be easily cleaned since they are so short.
Old Jan 7, 2008 | 02:02 PM
rayluka's Avatar
rayluka
I saw those rubber hoses and thought it was a bubbafication.
Old Jan 8, 2008 | 11:47 AM
Emeightch's Avatar
Emeightch
Why do you think someone would plum those lines in solid? No wonder I had leaks all over the place.
To Trans line Help Needed (Pic)
