From: Las Vegas - Just stop perpetuating myths please.
Finally got my beam wrenches.
Finally bought my beam torque wrenches from Sears yesterday. Used my Craftsman Club card and got a 1/2" and a 3/8" for $45 out the door. The Sears store will match the catalog sale price but without the shipping ($10).
Been waiting for a sale on good beam wrenchs for years now i got both sizes. Great inexpensive wrenches for a back-up that never lose their cal.
I'm curious, why did you choose beam style over the clicker style torque wrenches?
I can remember when beam style were the only type available.
Are they more accurate than the clicker style?
Kurt
Clicker type torque wrenches have to be calibrated periodically to maintain their accuracy but are easiest to use in a lot of applications. A good quality beam type torque wrench generally will maintain it's accuracy over it's working life. One of the ways you check the accuracy of a clicker type torque wrench is against a good beam type. Dial type torque wrenches are probably the most accurate of the three types and operate very similarly to a beam type. I have, and use all three kinds depending on what I am doing and which wrench allows me the access to the item being torqued. Small, inch pound dial types (0 to 30 inch/lb, or 0 to 75 inch/lb) are what you would use for jobs like setting up a steering box or wheel bearings, etc.
Stock 76,
Good information; thanks.
I have a clicker and now if I can find someone with a beam type, I can see if my clicker is accurate or not.
Thanks for that useful tip,
Kurt
Kurt
Beam wrenches are sometimes harder to use in tight areas but with the pivoting handle are accurate and repeatable. Were as other type T-wrenches u may have some error with changes in your grip location on the handle. The pivoting handle on the beam wrench eliminates this.
Yea i recently found my Hobo Freight torque wrench off after i snapped off a couple of bolt heads. I can calibrate my wrenches at work but that don't help when i need a good wrench right now or on a weekend. And if my HF T-wrench continues to slip i will up grade that also to Craftsman.
Now i need to find 2 hard shell cases that will fit - or maybe 1 large one.
