Body Dolly
Old Jan 9, 2008 | 10:27 PM
hicswa's Avatar
hicswa
Default Body Dolly
Where can I get a set of blueprints to build a body dolly for a 1975 coupe?
Danny
Old Jan 9, 2008 | 10:45 PM
coinwasher's Avatar
coinwasher
See the attached link for some pictures of the one I built out of scrap steel and some old wheels. All I need was the demensions of the four inboard (cage) body mounts.
http://s120.photobucket.com/albums/o190/coinwasher/
Old Jan 9, 2008 | 11:08 PM
hicswa's Avatar
hicswa
Thanks, Took a look and it seen pretty straight forward. I'll get the diminsion for the frame from my assembly manual. Looks like you guys with them backhoes have all the fun though. .
Old Jan 9, 2008 | 11:27 PM
coinwasher's Avatar
coinwasher
Sure made it easy to patch up and wire underneath. Good luck with you project bud.
Old Jan 10, 2008 | 02:06 AM
avner's Avatar
avner
Look at Linda & Barry's website
http://lbfun.com/Corvette/Tech/vettetech.html
Avner
Old Jan 10, 2008 | 09:11 AM
hicswa's Avatar
hicswa
Jackpot! Thanks for the info. Should make this one a sticky.
Danny
Old Jan 10, 2008 | 03:37 PM
DJordan442's Avatar
DJordan442
i put my dolly together in less than 2 hours last weekend based on some of the pics that have been posted on this site. i picked up the following from the Home Depot for almost exactly $100:
1 - 4x4 (8 ft)
7 - 2x4 (8footers)
4 - 5 inch poly casters (these were $11-12 each but make rolling sooo easy
16 - 3/8 inch lag bolts (6 inch) with washers and nuts
really easy to put together. the only problem that i had was that i cut the 4x4 into 4 equal 24 inch pieces but when adding the wheels, the total dolly heigth was too high and i couldnt lift the car high enough. ended up cutting 4 inches off of each 4x4 but it all worked out and the car is not rolling around in the garage.
let me know if you want some pics.
Old Jan 10, 2008 | 10:59 PM
hicswa's Avatar
hicswa
Could I have some pic Please? I'm work better with visual.
Danny
To Body Dolly
