Wheel wells
Old Jan 9, 2008 | 11:06 PM
Yankees031's Avatar
Yankees031
St. Jude Donor '08
Default Wheel wells
Has anyone ever painted there wheels wells to "spruce them up"
Old Jan 9, 2008 | 11:08 PM
Green73's Avatar
Green73
yep.. flat black or a semi works well
Old Jan 9, 2008 | 11:16 PM
vettehed's Avatar
vettehed
go to autozone or walmart and buy 4 cans of the spray undercoating. It will freshen up the undercoating the factory sprayed in there to cover up the body paint and black out the wells.
Old Jan 9, 2008 | 11:28 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
If you're down to clean, bare fiber the Krylon Fusion paint works quite nicely.
Old Jan 10, 2008 | 12:21 AM
chvet73's Avatar
chvet73
Default Undercoating
I did the undercoating too. Was easy and effective. It's a very forgiving finish.
Old Jan 10, 2008 | 12:47 AM
onaqwst's Avatar
onaqwst
rustoleum here...... sticks a bit better and tough
b
Old Jan 10, 2008 | 06:19 PM
Yankees031's Avatar
Yankees031
St. Jude Donor '08
No problems with any overspray?
I was thinking of brushing on some marine bottom paint
Old Jan 10, 2008 | 09:46 PM
John Ulrich's Avatar
John Ulrich
Get some low-tack mashing tape and carefully mask your wheel well edges.....Don't press the tape totally flat... you've got fresh paint.
I've always used Semi-gloss or Matte/Satin Rustoleum spray, but brushed on would eliminate taping!
Tape over the body mount rubbers etc....looks bad when the whole area is "spray bombed" including soft parts.
There is an aluminum plate in the left rear wheel well. Polish it out.
Steel wool or scotch bite some polish on the mufflers to brighten them up so when you look past the rear tire you see "fresh" looking steel.
Old Jan 11, 2008 | 08:32 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
I just redid mine. Took seam sealer and redid all the seams and brushed a coat on the bottom of the upper fender surfaces to keep the occasional rock from flying up and starring the fenders from underneath. Masked the individual bushings off and sprayed undercoating over it. Letting it set up for a couple of weeks and then will paint on top of it. Looks good and I know its all sealed up!
Old Jan 11, 2008 | 08:37 AM
BenUK's Avatar
BenUK
What was the original underbody finish on a mid-70s C3? The underseal on my '76 seems patchy and since I'm taking the body off I'm curious to find out what it would have been like. I don't want to cover it too obviously with some ugly-looking (but smart) modern alternative.
Old Jan 11, 2008 | 08:43 AM
Trae1976's Avatar
Trae1976
Another for Undercoating. Mask well, spray, and remove the masking before the stuff dries. It looks good and repels water pretty well.
Old Jan 11, 2008 | 03:01 PM
79inSD's Avatar
79inSD
I painted the brakes cals red at the same time.
Old Jan 11, 2008 | 03:13 PM
eastltd's Avatar
eastltd
It may just be me, but I'm not a big fan of rattle can rebuilds. To me if you are going through the trouble of detailing your underbody it should be primed, sealed and painted with a quality automotive paint system.
Fully restored, the car should look as good on the bottom as it does on the top.
As for the rustproofing, think about how hard it was to take that stuff off. Are you sure you want to put it back on?
Just my 2 cents!
Old Jan 11, 2008 | 05:13 PM
72GACRZR's Avatar
72GACRZR
Regardless of what you use, you can clean the overspray off, use WD-40 for the under coating and a clay bar system for paint, then re-wax or polish.
To Wheel wells
