Need help removing 78 mirrors
Old Jan 9, 2008 | 11:41 PM
swtato's Avatar
swtato
St. Jude Donor '05
Default Need help removing 78 mirrors
Any suggestions on how to remove the mirrors of my pace car? I took the door panel off, with the window down one of the bolts is 3/4 blocked and the other is at a funny angle and hard to reach with a socket? I want to remove the to have it painted. Any suggestions?
Old Jan 10, 2008 | 12:05 AM
rihwoods's Avatar
rihwoods
With window up,loosen the window's in/out adjustment screws at top of the door to allow space for 1/4" ratchet with 7/16" short socket to fit between window glass and door frame to get to the front mirror retaining nut.
Then for rear mirror retaining nut,loosen lower glass stops (philips screwdriver)and run window all the way down...
Old Jan 10, 2008 | 09:23 AM
swtato's Avatar
swtato
St. Jude Donor '05
Thanks.
Old Jan 19, 2008 | 04:38 PM
swtato's Avatar
swtato
St. Jude Donor '05
Where are the lower glass stops located?
Old Jan 19, 2008 | 06:01 PM
rihwoods's Avatar
rihwoods
Lower part of the vertical window channels...
Old Jan 19, 2008 | 07:59 PM
C3 4ME's Avatar
C3 4ME
I had to take the glass out on my 79 to get the mirrors off.
Old Jan 19, 2008 | 09:00 PM
swtato's Avatar
swtato
St. Jude Donor '05
removed the lower stopin the lower left on the driver door. Glass did no seem to drop any further? With a few extra hands and a little persuasion on the door frame. We were able to remove it.
Old Jan 20, 2008 | 10:06 AM
rihwoods's Avatar
rihwoods
My biggest issue was re-aligning window afterwards... Think pwr windows more difficult...
Old Jan 20, 2008 | 10:23 AM
spedaleden's Avatar
spedaleden
I had to take the glass out on my 81. Make sure you remove outer weatherstrip next to glass. I thnik it 3 or 4 screws. It makes it much easier to get glass out, roller doesn't get caught in weatherstrip.
Old Jan 20, 2008 | 11:54 AM
Glassbowtie77's Avatar
Glassbowtie77
I had to do the same thing on My 77.
Old Jan 20, 2008 | 06:20 PM
mark79,80's Avatar
mark79,80
What were the steps you took to take the window out?
Old Jan 20, 2008 | 06:52 PM
spedaleden's Avatar
spedaleden
Remove door panel and place window all the way down
Remove outer Seal 2 screws one located at each end of seal
Carefully pry out of six retaining clips
Take seal out
Remove anti rattle cushions
Put window up so to line up with two sash screws through acess holes in door and loosen nuts do not remove
Remove upper stops located on forward and rearward channel
Loosen all nuts on top of door so channels move freely
Now remove loosen sash nuts and carefully take out glass.
Old Jan 20, 2008 | 07:19 PM
mark79,80's Avatar
mark79,80
Thanks for the reply. You mentioned removing the rear upper
window stop but I wonder if this can be left in place? The other
end of the roller that is in this channel is in the sash channel.
Old Jan 20, 2008 | 07:50 PM
swtato's Avatar
swtato
St. Jude Donor '05
MAybe I was just lucky but it was alot less work to have a friend unscrew while I spread the frame at the top wider with my knuckles?
To Need help removing 78 mirrors
