Removing Door Panels
Old Jan 12, 2008 | 06:34 PM
KennyZush's Avatar
KennyZush
Default Removing Door Panels
Hello,
Any special procedures for removing the door panels on a '77?
Doing some wintertime work and this is next in line.
Thanks,
Kenny
Old Jan 12, 2008 | 07:02 PM
original76's Avatar
original76
I've had the panels off my '76 too many times to count and I'd think it would be the same for a '77. Remove screws on front and back edge of door, remove lock **** (it has a horseshoe shaped snap clip) I've usually carefully pried it out and poped it off with a long bladed screw driver, unscrew closer handle ( two screws), Put the window down and carefully pull the bottom of the panel out, and slide forward and up to clear the door handle. I hope you find plastic under the panel. Be sure to put the plastic back in when reassembling. Hope I didn't forget anything.
Old Jan 12, 2008 | 07:59 PM
KennyZush's Avatar
KennyZush
Awesome tips....
Thanks a bunch.
Kenny
To Removing Door Panels
